New 712M owner
Posted: Sat Jan 24, 2009 12:52 am
by Ali
Hi all
I bought a 712M recently and I need some clarification
How hard is the clutch pedal to depress? The shifting is normal but very hard!! Is it normal???
How is the correct way to shift the reverse gear???
If someone has the owner manual in PDF format, please send me to : alisalim99@yahoo.com
Thanks in advance.
Posted: Sat Jan 24, 2009 1:49 am
In all the trucks that I have driven, the clutch is as easy as any vehicle to operate. If the clutch releases properly then the shifting should be smooth and easy (assuming the right tranny oil is used, and it is not too cold). Reverse in these trucks can be tricky, but is easy to adjust: you need to push the shifer DOWN (towards the ground) and while holding it down, push away from you into reverse. The pin and plate that prevents getting into reverse without pushing down are often not postioned right; lie on the ground and look at the shifter where it exits through the floorboards, and have a helper attempt to shift in and out of reverse. It is easy to see what is going on, and just loosen the bolts that hold the plate and move it so it goes smoothly into reverse when pushed down. Not hard, just hard to envision until you see it work from below.
I can't say what might be making your clutch or your shifting hard (the mechanical experts can better help here) but the reverse lockout is rather easy.
Best of luck,
Posted: Sat Jan 24, 2009 6:26 pm
by Kirby
Jimm391730 is right on, I had a rough time getting into reverse, did just what he said (found it on my own - by looking under for a problem?) bingo bango.... done!
So where are you? and where did you get your 712?
Shfiting into reverse
Posted: Sun Jan 25, 2009 3:57 am
by Jon_Gilbart
If I'm not mistaken, I believe you are supposed to push the shifter all the way to the left until you feel resistance, then push a little further until you can't go further left (like you're going into 1st), THEN push the shifter down, THEN push the shifter forward. When I tried to push the shifter down, then go all the way to the left and up, reverse was difficult to find and sloppy. I can't remember if I read this in the owner's manual or somewhere else, but ever since I started shifting using the 1st sequence listed above, it has been very easy to find. Hope this helps. -Jon
Posted: Sun Jan 25, 2009 6:38 am
by Ali
Thank you all Jimm391730, Kirby and Jon.
I will try to see it from under the Truck.
Kirby my location is in the Middle East, my country called Oman.
I got a 712M & 712K from my country army auction.
Thanks all
Posted: Sun Jan 25, 2009 8:49 am
by andy
Ali, welcome. I think a 712K would be a lot of fun.
If I may ask, what did Oman replace the Pinzgauers with? More Pinzgauers...the 716's and 718's, or with something different? Just curious.
Andy
Posted: Sun Jan 25, 2009 11:23 am
by Ali
Hi Andy
still some 712 & also the 718 in service but recently i saw Panhard in service.
http://en.wikipedia.org/wiki/VBL
Ali
Posted: Sun Jan 25, 2009 1:03 pm
by andy
Ali, interesting. Panhard has a TD and what appears to be a fairly decent operating range. Is the Panhard capable of carrying 12 to 14 troops like the 712? I noticed from your link that the US has some also.
Amzaing what you can learn on this site.
Andy
Posted: Sun Jan 25, 2009 10:48 pm
by Ali
Andy, you are most welcome
the Panhard is carrying upto 3 troops,
VAB by Renault is in service here to carry 12 troops,
http://en.wikipedia.org/wiki/V%C3%A9hic ... lind%C3%A9
Ali
Posted: Sun Jan 25, 2009 11:36 pm
by andy
Ali, thank you again for the information and an interesting link. I'm tempted to make some sort of snide comment about French military vehicles having 5 reverse gears and one forward, :lol: but I won't.
Both vehicle must have something going for them to be in such wide spread use.
Thank you again,
Andy
