swapping out the original front seats
It sounds like folks are much more comfortable using seats they've scavenged from any number of other types of vehicles (in Europe, it sounds like the seats from a Smart work well).
Has someone come up with a "standard" seat frame that they have fabricated that works well with the seats from a...whatever?
I'm looking for the easiest / most cost effective upgrade to more comfortable seating and their frames.
Any suggestions and photos of what you come up with will be appreciated.
Thanks!
Thanks!
1974 712M - sold
1973 710M - sold
1974 712M - sold
1973 710M - sold
Maybe you want to take a look at these pictures: http://pinzforum.kiruna.de/viewtopic.php?t=1928
I used the seats from a Smart, as they are small enough and very low.
Especially on the co-driver side there is only very limited space available, there aren't too many seats that fit.
You also need to watch the height, there is no room for high consoles. If the seat is mounted too high, you hit the roll bar with your head.
The last criteria is the weight. To access the engine you have to be able to lift them out from time to time. Don't take a too heavy seat...
I mounted the seat on the stock rails plus an adapter made of 30mm angle iron. You see the adapter in one of the pictures (sorry, the only one I have), hopefully it gives you an idea of the part. I don't think there is something like a 'standard' seat frame, as every seat is different.
Wolfgang
Wolfgang
Alot of us here have used honda CRX seats. You need to have a seat that is about 19" or smaller. The passanger side will not fit much wider than that. I paid $150 for both of mine that were pretty much brand new on EBAY. I made a hard mount install to where they Dont adjust forward and back. Pretty easy to figure out what needs to be done when you have the seats.
mike
mike
ITS NOT A F*&$%*# HUMMER!!!!!!!!!!!
Cheap seats
I played around with a couple of different seat options and never found anything that would get me lower in the 710 than the stock seats
What I finally came back to that I am pretty happy with is a piece of 3" seat foam cut to the same shape as the original seat base and covered with vinyl that is a basic pillow
On the drivers side I just pulled the wood based seat pad and replaced it with the pillow sitting in the seat pan, on the pass side I riveted a piece of metal to the bottom of the seat frame and set the pillow on that
That lowered me at least 2" in the truck and I never feel the odd shapes of the drivers seat pan and I have a skinny bony butt (6'2" 180lb)
I used bulk 1/4 shock cord from REI to lace back and forth thru the seat back to replace the old rubber and varying the number of passes thru each of the channels gave alot of extra lumbar support
I liked those Corbeau seats and I'll certainly consider those if I find an extra $1000 in the seat cushions of our sofa!
I think something used from a recycling (AKA junk) yard is going to be a better option for me.
1974 712M - sold
1973 710M - sold
1974 712M - sold
1973 710M - sold
Another option you might try on the factory seats is duct tape. I've heard of other pinz owners using it. Might save you a couple of $$.texas pinzgauer wrote:I liked those Corbeau seats and I'll certainly consider those if I find an extra $1000 in the seat cushions of our sofa!![]()
pinzwheeling said:
Do you happen to have the model number/style that you used?I have a set of Bestop seats and they are some of the best I've tried. Very low (almost non-existent) bolstering on the seat bottom and about 1/2 inch higher than stock seats.
I like my Recaro's, but it took a fair bit of engine cover modification to get them in!
http://www.ozpinz.com
My 710 has the Recaro knockoffs from CWR and the 712 has some Honda seats. Which model Honda I don't knw. I would not recommend the CWR seats, not that they aren't cofortable, but they have not held up.
The Honda seats in the 712 are much more comfortable. My 5' tall daughter can drive the 712 with the Honda seats and can't reach the pedals on the 71o with the CWR seats.
Both types could be lower to enhance the view from the cab and I'm only about 6' tall.
Andy
Andy
This topic seems to come up on a regular basis. Awhile back I made a post on the Rhino seats I installed.
viewtopic.php?t=3334&highlight=rhino
The nice thing about Rhino seats is that they are readily available new in a wide range of prices and they fit on the passenger side. I mounted them on a set of stock seat frames I bought from Andre Swanson.
The modification to the seat frames was simply to have a couple of pieces of flat stock welded across on the frame and then cut off the back and drill a couple of holes in the new cross bars to mount the seat and your done.
Bruce Berger
'72 Pinzgauer 710M 2.6i
