headlight install
Posted: Sun Feb 01, 2009 12:41 pm
by purplePinzer
I got new headlights but i am not to sure how to get the old ones out haha, help!
headlight install
Posted: Sun Feb 01, 2009 2:51 pm
by krick3tt
I just replaced mine, new bulbs from EI. The screws at the bottom of the rim were a bit nasty to get out (rusty) but after that no real issue. PM me if you want a play by play.
Morris
headlights
Posted: Sun Feb 01, 2009 8:21 pm
by texas pinzgauer
I can help you with this as I just installed the KILLER H-4 headlight set from EI...one of the most useful and beneficial upgrades you can make to your Pinzgauer. There's a screw (could be straight blade or philips) at the bottom of the headlight retaining ring. Remove that and swing that retaining ring in an upward arch (there's a little notch at the top.
Once you have it out, you'll see three very small screws in a retaining ring that you remove. Once those are out, you gently work the headlight assembly out and I used a small screw driver to remove the plug at the rear.
While the outward most ring was out, I roughed it up with some fine sandpaper and resprayed it and also used some vinyl protectant on the foam gasket just inside that outer most ring.
Same directions to reinstall. Hope this helps.
Posted: Mon Feb 02, 2009 8:50 pm
If you use a LONG bladed screwdriver, you might note that there is a convenient hole in the bumperettes that let you get to the bottom screw at the correct angle.
headlight install
Posted: Mon Feb 02, 2009 11:37 pm
by krick3tt
Yeah, I was thinking about that as I tried to get a screwdriver past my custom bumper. The one I got from EI that holds my winch.
Had to use a very short one and that did not have much torque to turn the rusty screw.
Sometimes the mods can get the better of you. Just have to be flexible.
Morris
Posted: Tue Feb 03, 2009 11:06 am
by texas pinzgauer
I had to nearly remove the custom bumper that Thilo had fabricated for my truck too.
So the easy 15 minute project took a bit longer to complete.
Installing the H4 lights is definitely worth the trouble.
Posted: Wed Feb 04, 2009 2:45 am
by GenevaPinz
I am sure the H4s are an improvement over the original headlights, but personally I chose to only upgrade the lightbulbs. The thing that I don't like with replacing the full headlights with H4s was losing the parking lights...
Jan
headlights
Posted: Wed Feb 04, 2009 9:29 am
by texas pinzgauer
Jan,
I had the same thought when I cut those parking light wires but I was already committed by that point in the project. If keeping that parking light capability is a priority then Jan's approach is a better alternative to a total assembly replacement.
David
headlight install
Posted: Wed Feb 04, 2009 10:38 am
by krick3tt
I only did the bulbs. Did not want to lose anything that was there already, but while everything was out I cleaned, sanded and repainted everything except the shiny surface. Even reglued the rubber that was starting to come apart and get loose. At least the mysterious part is no longer.
Every time I do something I learn more about this vehicle. I think that is where the guys that do a total rebuild have it all over the rest of us and know where everything is and how it works. some of the pictures make me very envious. My hat is off to them.
