Questions? Message me.
Please use the word Pinz or pinz in subject line to flag
Located in Southern CA - border of Orange County and LA county
- Purchased from dealer in Prescott AZ in 2014
- Overhauled by dealer at time or purchase
- estimated less that 5k < miles since
- Ca street legal registration is up to date and current
- PinzSSI ignition module
- improved start from cold
- improved idle before warm
- aftermarket Mbenz taillights
- improved visibility safety compared to factory
- Still 24v
- Speedometer / gas gauge non-metric units
- brush guard on front end
- 24v battery maintainer/ charger
- waterproof marine grade
- in battery box
- standard 3prong 110v AC plug
- occasional around town on weekends
- trailered to desert for off road adventures
- maintained with factory spec oils and lubes
- consistently use of quality fuel - no ethanol ever
- typically union76 brand
- one headlight on low beam intermittently works
- likely needs new reset-fuse (dashboard) (current 20-40years old)
- lite surface rust in isolated areas / non-structural
- Southern CA is fairly arid is negligible
- 1 bolt-on exhaust manifold at engine block broken
- canvas over cab is original (unknown age)
- canvas over truck bed was new at time of purchase
- windshield wiper motor may need replacing or repair
- some minor weeping at seals between trans and engine
- NO issues with fuel tank lining as ethanol contaminated fuels were strictly avoided
- NO spray-on liners / (no rhino coat)
- shifts between gears well / lo - high transmission shifts well
- hydraulics for 4wd / diff locks all work
- side rail bumper guard are “synthetic wood” material / durable but showing age
- tires original to time of initial purchase
- includes original surplus Ax (passenger side)
- Includes original surplus shovel under utility box
- original speedometer
- various bulbs connectors etc
- case of oil factory spec (NAPA)
- flex pipe aftermarket exhaust system (never installed)
- see note about manifold bolt
- factory drivers manual german / english
- more/etc
- trailer used to haul pinz for off roading trips is also available - if interested
- flatbed 2 Axel 7000k
- 2 3/4" ball (I will double-check)
- additional cost not included in price above
