WTB want to buy windshield tension brackets and knobs
Posted: Thu Jan 14, 2016 12:15 am
by NEWFISHER
Looking for the verticle spring loaded windshield retaining brackets that hold the frame when folded down. They mount between the headlamp and the grille. I also need a set of knobs that secure the frame when the windshield is raised upright.
I dont need the headlamp guards with the rubber footballs as I dont want to get into filling holes and repainting. I have an idea to fab a stop.
Scott at EI thought he had some but hasnt responded to emails or phone messages. SAV hasnt had any and buypinz Bob doesnt have a set but might have a lead.
Re: WTB want to buy windshield tension brackets and knobs
Posted: Thu Jan 14, 2016 2:36 pm
by Haf-e
If you are going to fabricate your own supports for the windshield then I would suggest fabricating the hold down mechanism as well since they need to work together and it is not that fancy of a part.
As far as the knobs go - I've seen nice one with the puch logo on them - but you might be able to find something similar (without the logo) from a source like McMaster-Carr supply or similar.
You also might check with some of the European parts suppliers such as Haflingertechnic etc.
Posted: Fri Jan 15, 2016 1:11 am
by NEWFISHER
Thanks for the link. I would really like the o.e. ones.
Posted: Sat Jan 16, 2016 5:48 am
by Hotzenplotz
Posted: Sat Jan 16, 2016 11:54 am
Here is the Steyr # for the Knobs with the Puch logo 7111721182 (fixing screw).
They are special order only as far as I remember.
Posted: Sat Jan 16, 2016 5:00 pm
Jim LaGuardia wrote:Here is the Steyr # for the Knobs with the Puch logo 7111721182 (fixing screw).
They also don't fit into a Swiss - you will have to drill and tap the existing holes
Posted: Sat Jan 16, 2016 8:25 pm
They are direct fit on the Swiss units, I have put them on several trucks in the past.
Posted: Sat Jan 16, 2016 10:41 pm
by NEWFISHER
Thank you allnfor the info. I have sent emails requesting the parts, we will see whats still available.
If the knobs dont fit, I own a tap set
Posted: Sun Jan 17, 2016 8:03 am
Jim LaGuardia wrote:They are direct fit on the Swiss units, I have put them on several trucks in the past.
Well you would know better than I would
I was just going off of Rick's old thread
http://real4x4forums.com/PinzgauerBBS/v ... 443#p33443
Thanks for clarifying
Posted: Sun Jan 17, 2016 12:09 pm
by pinzinator
I did have to drill and tap, maybe I had a unique frame or set of knobs.
Posted: Tue Jan 19, 2016 3:59 pm
by NEWFISHER
Found a set of knobs ( CWR ) and still on the hunt for the inner brackets and the outer hinged pieces or I may have to fab something.
