Pinzgauer 712M for Sale in Texas
Posted: Sat Mar 26, 2016 3:29 pm
Time has come to find a better home for my beloved 712M. I bought it 12 years ago and I am the second owner (If you count the Swiss Army as one).
Now the Good things:
I have done quite a few upgrades such as tie rod ends, civilian distributor, spark plugs and cables, pertronix ignitor, Electronic VDO gauges (Speedometer, Tachometer and Fuel) Rebuild carburetors less than two months ago. I repaint it in desert tan and at time I replaced the passenger side panel due to rust in it (only the panel was affected). I rhino lined the back of the pinzgauer, Put brand new Hella headlights with 100/90 watts bulbs, the doors were upgraded with aluminum panels to match the floor ones, all bolts and nuts were replaced with stainless steel nuts (that alone was more than 700 bucks).
The truck also has been fitted with Diesel stop lights for better visibility and yes they work perfectly.
I removed the gas tank and send it to be relined internally since the red film was falling apart. The new film is an plastic one that has lifetime guarantee, Tires have 90% thread, and I will also give you all the replaced parts so you have them as spares. I will toss an additional rear door from a 710K (yes with glass and all) since I wanted to put a hard top one day (that I never did).
I will also add BN4 heater unit removed from a 710K which I wanted to install and never did when I moved south and had no need for it.
I am asking 23K.
The bad:
It needs new axle boots they are the original yellow ones and are cracked.
The Ugly:
It needs a new top. The clear plastics are brittle. I asked at an upholstery place and they were charging me 20 bucks per window. So 20 x 5 = 100 bucks to make it look decent.
Thanks.
https://flic.kr/p/ELHXe1
https://flic.kr/p/ELVjxv
https://flic.kr/p/Fh49q3
https://flic.kr/p/ELJ17W
https://flic.kr/p/ELJ2as
https://flic.kr/p/FxZsLW
https://flic.kr/p/FDSQHd
https://flic.kr/p/Fh4egf
https://flic.kr/p/Fh4f1G
https://flic.kr/p/ELVrDV
https://flic.kr/p/FGaK2M
https://flic.kr/p/FxZzy3
https://flic.kr/p/FxZAL3
I am asking 23K.
The bad:
The Ugly:
Thanks.
