hairy volvo c303 TGB on eBay
- bonefish635
This has been listed a few times but hasn't hit the mark. Looks pretty hairy. Any idea what the hinged rear framework would be for?
http://www.ebay.co.uk/itm/VOLVO-TGB-111 ... 23488680c4
Tony
Tony
- hairy c303 rear view.jpg (285.54 KiB) Viewed 7107 times
- hairy c303.jpg (211.98 KiB) Viewed 7107 times
1973 710K
2001 Landcruiser Amazon
2007 Range Rover Vogue (sold)
Re: hairy volvo c303 TGB on eBay
The back opens up and there are equipment draws behind as I remember from Mopar's truck.
'76 710K
- bonefish635
I wonder why have it at all? Doesn't seem to serve any structural purpose, and looks pretty beefy so would add a fair weight.
1973 710K
It so you can hang a lot of weight off the back and pretend t be doing "wheelies"
John
John
Looks more like a vehicle recovery device. Drop it, pull onto frame and drag out of way.
Agreed and would somehow work with that rear winch as it is mounted so high.Jim LaGuardia wrote:Looks more like a vehicle recovery device. Drop it, pull onto frame and drag out of way.
leverage points are all wrong for using the winch to lift the hoops if they had any weight on them.
John
John
- David Dunn
Me thinketh it is an example of a cutting torch, welder and a truckload (lorry) of beer.
It appears that once he removed the original tank killer’s folding roll cage, he cut and reuse as much as he could, and added as needed.
The front and rear bumpers are original, as are the front diagonal braces are from the rear lateral braces from the original folding cage.
From this pic, you can see where he would have gotten most of the pieces
Here's a pic of what one looks like folded down. Guess which is the fron and which is the back?? LOL
- folded.jpg (209.98 KiB) Viewed 6861 times
1974 712M AKA the Banana
1987 718M Now Sold
1975 Volvo TGB1111 Now Sold
1963 404S Now Sold
1987 718M Now Sold
1963 404S Now Sold
With all that weight out the front it looks like it is standing on tip toes! Any bumps you went over would lift the rear wheels off the ground very easily.
John
John
It is not so noticeable, but my pinz does the same thing. Lower in front than the rear. Assuming that when fully loaded, as in full of troops or a payload the thing will level out. When I was trying to determine if it would fit in the garage, I measured the front and it would pass easily...not noticing that the rear was taller and scraped the header. Tore the middle clip for the top completely off. Also had to remove the antenna mount.
A video of this rig in Scotland:
https://www.youtube.com/watch?v=zeS22iQw2b4
Not sure how to embed a video on this forum.
- bonefish635
Plenty of things would have been stuck long before that thing eventually was. I don't know much about the Volvos, but when it does get stuck at the end, it seems to lack the ability to lock all the diffs- only the front wheel on the visible side is turning. Do these volvos lack the Pinz' allround diff locking capabilities?
Tony
Tony
1973 710K
In the video write up it says no lockers, so I don't now if that means he didn't use them, or they were not installed or broken...
