Tune-up problem
Posted: Thu Nov 11, 2010 10:02 pm
I just restored a '64 Austrian Series 1, including a rebuilt engine. Everything was new in the fuel/ignition system, except the distributor and cap. Tank cleaned, new fuel lines, etc.
After about 30 miles on the truck it started to lose power, like a fuel starvation problem. Knowing most fuel problems are electrical, I went over the entire ignition system, all was OK.
Next the fuel lines were replaced (again), and it ran OK for about 3 miles, then less power than before. Off came the carb, it was like new since it was just rebuilt. Still no power. Electric fuel pump did nothing. I was stumped!
Back to the ignition system. Timing good. New coil OK. Wires OK. Plugs and points OK.
Last on the list was the condenser, which was also new. Without proper test equipment I gambled $7 that this new device was no good (the engine would run OK, then run bad, then OK, then bad). Sure enough, changing the condenser solved everything and the Haflinger runs like new again.
I've been working on engines since High School and never had one frustrate me like this one did! And to think that the Haflinger engine is about as simple as a lawn mower, without the magneto.
