Reborn as Curry-Pinz
Mods, resto projects, library resources and anything else diesel related.
sealan
Malaysia
Re: Reborn as Curry-Pinz
Post by sealan »
After a long time,, here's a continuation of the build...
Portals are out to be machined for a different PCD and with studs fitted
IMG-20160601-WA0011 (2).jpg (112.41 KiB) Viewed 5695 times
Curry Pinz - Pinzgauer 718M 6x6 on 33" tyres
CurryLux - Toyota Hilux with SAS on 35" tyres
sealan
Malaysia
Post by sealan »
Just to share some of the Mods I have decided to run on the Pinz, in consideration of the super hot weather and commonality of parts in our part of the world:-
1) Re-machine new PCDs 139.7 , 6 holes to match most Pickup Trucks PCDs here.
2) Separate Oil Cooler for the ATF away from the radiator
3) Add on Engine Oil Cooler
4) Fit in adapter to use commonly available Toyota Oil Filter.
5) Recore the radiator and remove the built in Transmission Cooler
6) Simplify the piping and routing for the Engine Coolant
7) Junk the old AC and add on a more efficient AC with double blower.
Future mods:-
1) Add in a more modern Fuel filter which has built in Diesel Primer Pump and Water Sensor.
sealan
Malaysia
Post by sealan »
After some of the mods was completed, the Pinz was released for it's short lived freedom to roam for 2 weeks...
Pinz After Mods.pdf
(2.24 MiB) Downloaded 263 times
sealan
Malaysia
Post by sealan »
Anyone knows what do these notation means?
What are these notations?
sealan
Malaysia
Post by sealan »
One of the last picts before Pinz goes in for its build and transformation
Pinz in its ori form
20160805_175746 Cropped.jpg (138.44 KiB) Viewed 5651 times
The true Pinzgauer´s
Post by The true Pinzgauer´s »
this are copy labels from mark of conformity of break´s, lights, seat belts, seats and glasses. https://de.wikipedia.org/wiki/ECE-Pr%C3%BCfzeichen
sealan
Malaysia
Post by sealan »
The true Pinzgauer´s wrote:this are copy labels from mark of conformity of break´s, lights, seat belts, seats and glasses. https://de.wikipedia.org/wiki/ECE-Pr%C3%BCfzeichen
Thanks for this, learn something everyday
geckoadventure
New Zealand
Post by geckoadventure »
Hey where's the updates?
sealan
Malaysia
Post by sealan »
Am having trouble resizing the pictures into a smaller size to post...
Need some tips here.
Almost 1,400 picts to choose from...
Promise not to flood the forum
I think the limit is 2Mb
You can just use a free online resizer
Example: http://www.picresize.com/
Never used it but just Google and find one you like
sealan
Malaysia
Post by sealan »
TechMOGogy wrote:I think the limit is 2Mb
Thanks for the hints... will make some time to reorganize and resize picts for postings
