I saw this set up first hand at our treffen,very nice! Uneven tire wear would be eliminated by adjusting suspension pressure. Following this truck on the trail I could see the changes in attitude of the truck when approaching obsiticles,cool! Well this is not my horn to blow,so carry on Air-Man!
Well air suspension certainly works on the Range Rover so I can only assume it would have benefits on the Pinny!
I, like a lot of others on the forum would love to see the Pinny in action so to speak .... Bring on the pics and videos!
We have been working on this air suspension system for a while, with the rear system being designed first, which currently has around 4000 miles on it, and the front system which has a little over 1000 miles on it.
We have found that the ride is much improved, with less road noise and vibration, and as Mark mentioned, the abitlity to lower the suspension so that the tires wear evenly. We have added a CO2 bottle, and a set of switches/pressure gauges on the dash, so that we can monitor and manipulate the air pressure on each of the 4 independently and on the fly. The ability to change the pressure according to the terrain has made the truck alot of fun to drive. (IE: Driving down steep slopes we can decrease the rear suspension height, as we choose)
This system uses industrial airbags like those found on large semitrucks/tractors. One of the beauties of the stock Pinzgauer suspension system is how easy it is to work on. One of our goals with the air suspension system was to not significantly alter the existing support structure, but to take a "bolt on" approach as much as possible. So we utalize the existing shock and spring mounts. The travel is simular to that of a stock Pinz, we are just able to utalize all of it. The airbags have internal bump stops and the rear uses a slightly modified stock limiting strap. A slighly modified stock limiting strap can be used on the front, but a recent update to the front system uses two shocks in place of the stock limiting strap (using the shocks as the limiting strap).
I'll post some more photos of the system shortly, and figure out how I can get my videos online.
M Wehrman wrote:I saw this set up first hand at our treffen,very nice! Uneven tire wear would be eliminated by adjusting suspension pressure. Following this truck on the trail I could see the changes in attitude of the truck when approaching obsiticles,cool! Well this is not my horn to blow,so carry on Air-Man!
Mark
BTW ,truck still running OK?
Mark, Thanks for your help at the SWPA Treffen, the truck is running much better once we played with the carb a bit.
sorry guys- should have been more specific. These pictures on the yahoo pinzgauer group's gallery have had me searching for a while. The Idaho 8B plate had me curious too. http://ph.groups.yahoo.com/group/pinzga ... rowse/90ec
The photogallery on the Yahoo Pinzgauer group shows an earlier revision of the rear air suspension system, we have since updated the mounting bracket on the shock. The gold color metal shown on these systems are chem film (MIL-C-5541) plated simular to that used on many Aerospace products.
We are looking at ways to be able to provide these air suspension kits, both front and rear systems, as well as an optional dash mounted control system. Building these kits individually would be rather expensive, but if there is enough interest to build say 5 or 10 sets at a time, we'd be able to lower the cost. So if your interested in any of these kits, let me know...
If your around the St George UT area and would like to check out the system, send me a PM I'd be happy to meet you.
You seem to have gotten the attention of a bunch of folks. How about providing us with just a general range of what you think this set up will cost for a 710 or a 712.
1974 712M - sold
1973 710M - sold
