Carb float tools - spot the difference!
Re: Carb float tools - spot the difference!
Standard size bleeder valve? That's the part I was missing and figured was the challenge.
audiocontr wrote:Standard size bleeder valve? That's the part I was missing and figured was the challenge.
I actually did find one....M7x1.0x34.
Would this work if I ground off the tip?
I didn't see a valve in my searches.
(Edited)
spandit
Post by spandit »
That should work. I don't know why valves are being mentioned - it's a bleed nipple
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
pcolette wrote:Would this work if I ground off the tip?
That says M4, and Spandit mentioned M7.
You're absolutely right - I labeled the photo wrong :(
It actually is an M7.
Had me seconding guessing myself! :mrgreen:
If anyone should happen to order the Dorman Bleeder screw (shown above) from Amazon, what you'll get is a box of 10 :shock:
They don't mention that anywhere that I saw.
10 valves that are the wrong size? :D
audiocontr wrote:10 valves that are the wrong size? :D
Nope - they are the right size. 7mm thread and 34mm long after removing the tip.
Tomorrow I'll add the tube and make the bracket.
I would take 2 from you
TechMOGogy wrote:I would take 2 from you
I'll try them out to make sure they fit and then let you know.
djw
Post by djw »
Paul, I would take a couple off your hands as well if they fit fine.
Same.
kpoling
Post by kpoling »
Paul: I'll take one if there any left. I can send you postage.
Regards, Kevin
'73 710K sold 01/22/2016
