First a couple of apologies. Not sure i am posting in the correct section and, even though I have searched, I have not really found a definitive answer yet. So please forgive and help.
I am planning on spraying waxoyl underneath and it sure would be easier if I could get the pinz on a lift. Steam cleaning the bottom was hard enough. I have access to a two post lift but there dose not seem to be good lifting points. I have seen the reference to the Gut Automobile use of a two post lift and their web site shows at least two on such a lift. How is it done? Do they use some type of apparatus to spread the weight. The photos do not allow a close inspection.
Any help is appreciated.
Keith
using a two post lift
75 Swiss 710K
W9YG
W9YG
Re: using a two post lift
I have s 710M and a two post lift.... and I haven't found a good way to use the lift on the Pinz.
Keith
Keith
I have put front lift arms at wheel well just where body lip starts to curve. And the rear as far back as lift arms will reach.
The lift arms should lock once you start to lift up. Place on body lip. After you lift about 6 inches, shake truck vigorously to make sure arms wont slip.
1975 710M
2000 Ural Tourist
2000 Ural Tourist
[quote="Brickren"]I have put front lift arms at wheel well just where body lip starts to curve. And the rear as far back as lift arms will reach.
The lift arms should lock once you start to lift up. Place on body lip. After you lift about 6 inches, shake truck vigorously to make sure arms wont slip.[/quote]
I have lifted my 710 and 718 the same way many times. Works great
718 on two post lift. No idea why its upsidedown.
- IMG_4324.JPG (131.17 KiB) Viewed 3775 times
Those are strong magnets!!!No idea why its upsidedown.
[quote="Jimm391730"][quote]No idea why its upsidedown.[/quote]Those are strong magnets!!! [/quote]
That's it!
That's it!
Thanks everyone. I just thought the side too weak to use as a lifting point. However the waxoyl is done after a long time on my back. Well worth it!
75 Swiss 710K
W9YG
W9YG
