Ultrasonic cleaners
Ultrasonic cleaners
Anyone have advice on using an ultrasonic cleaner for parts? I need to rebuild some diesel injectors and shops want around $120 for 5, which isn't bad but if you could buy (or demand one for my birthday!) a small used commercial cleaner for $150-$200 it seems like it'd be more wise in the long run and great for small parts.
Is it worthwhile, or do the shops that do this use much higher grade cleaners that do something a small one doesnt? I saw one demo that used three different sonic cleaning units for each injector job they do. (Why?)
This one is barely used and on craigslist for $200, for example.
- 00N0N_8x64LfSi0u3_600x450.jpg (28.28 KiB) Viewed 4487 times
Re: Ultrasonic cleaners
I know that the guys in the pinball hobby swear by these for small plastic parts and stainless guides, etc. Can't imagine you'd need a very expensive one to get good results.
- GenevaPinz
I have a cousin who is a jeweller, he has one to clean jewels that come for repair. This is great to shake the dirt off from any little crevice of the part to be cleaned.
I did not know it could work for greasy mechanical parts, but googling a bit I found that an Aussie company seems very happy with such a machine for carburetor cleaning: http://www.cleanacarb.com.au/picture-gallery.html
Jan
'72 Pinzgauer 710M
'72 Pinzgauer 710M
Not sure ultrasonic will work well for injectors, the dirty part of interest
is a rather small cavity internal to the device, it will be hard for the ultrasonic
waves to penetrate -- and you probably should apply a DC bias on the coil
so the path is open. Here's a El Cheapo DIY approach that would be my 1'st attempt.
https://www.youtube.com/watch?v=8rk0tKtiVic
I think the reasons for 3 different Ultrasonic baths would be so you put the dirty part in the first bath, gets rid of all the big external stuff, second bath with clean fluid allows you to run the injector whilst it is being cleaned. Third bath with more clean fluid allows final clean with injector running and now it will be very clean!
I certainly use a small ultrasonic cleaner for cleaning the Haflinger's Carb every once in a while. Very useful for cleaning jets.
John
John
Thanks.
And for many injectors it would be tough to clean them this way I'd guess but these are 1980's diesel injectors that come completely apart; nothing but heavy metal pieces all around. Unscrews in half and is open.
- M617Injector.jpg (7.95 KiB) Viewed 4439 times
Well that makes it more possible to get an internal clean, didn't know these injectors came apart.
Why not give this Lucas product a try on a couple of tank fulls first.
http://lucasoil.com/products/fuel-treat ... -treatment
Hi Guys,
We were not pleased with our ultrasonic cleaner. Spent roughly 3K with cleaner and special solvents to purchase a unit. Spent lots of tech time with the manufacturer, never got the quality or clean that we got out of straight up old school carb cleaner dunk tanks.
Ended up letting a buddy borrow it as it was sitting in the corner un-used. He swears by it for some of his parts! Figures........
Scott
Scott
Vallejo, California
www.expedition-imports.com
Vallejo, California
Well maybe they work on some parts better than others. Maybe I'll just stick to my paint can parts washer.
Sometimes these injectors, like any and esp. diesel ones, just have to be taken apart and cleaned. You can also do an inspection of the nozzle tip which is the wear part in these and is super easy to replace. You then dial it in with a shim to get the pop pressure in spec and its like new for another decade or more.
This is one of the companies that does cleaning professionally with sonic processes. http://www.pcfi-longisland.com/#!gallery/c161y
This is the diesel treatment preferred by pretty much any higher-end Merc. or diesel shop. This is a purge treatment that you cycle in the injection pump, not a tank additive. I do it once a year or so.
- LIQUI-MOLY-Diesel-Purge-500ml-LM1811.jpg (10.51 KiB) Viewed 4418 times
I use a cheap ultrasonic cleaner from Harbor Freight and I fill it with Berryman B12 Chemtool carb cleaner when I do carb jets and it works great. I just consider the cheap ones from Harbor Freight to be disposable and I've gone through a couple, but they have always worked well for me as far as carbs and various gun parts that otherwise can't be cleaned adequately. I consider it worth the money invested without a doubt.
Chris.
https://www.supanik.com/pinz
Vince,VinceAtReal4x4s wrote: This is the diesel treatment preferred by pretty much any higher-end Merc. or diesel shop. This is a purge treatment that you cycle in the injection pump, not a tank additive. I do it once a year or so.
I'd like to try doing this on my 300GD. Is there any advantage to getting the kit from dieselgiant.com? It seems like I could source the items elsewhere and save a few dollars. Do you also replace the injector return lines once in a while?
Thanks!
My kit is just a wide-mouth juice bottle with two pieces of fuel hose. The purge bottles only cost about $11 so their kit seems way over priced to me. I can buy it locally at my NAPA. Amazon has a good deal on it too.
Yes, definitely replace the return lines and make sure you get fresh hose and not some that's been sitting on a shelf for 5 years. I was sent a piece that lasted about a two months before I got dripping at two of my injectors... it was new hose but dry-rotted under that cloth!
Thanks Vince! I ordered a couple of Purge bottles from Amazon and I have the filters. Probably can find a juice bottle and the right fuel line in my shop.
Belmetric carries the cloth covered return line. Am I correct that it is 3.2mm?
I don't recall off-hand. I'm just going to order my parts from Mercedessource.com from now on. They try hard, support Merc. diesels and have some great stuff so even if its $2 more, I will give them the business.
