I am looking on installing a CB in the 712 and want to get a good unit. Any of you CB buffs have a good suggestion for a unit that is $50-$100, Cobra-Uniden-Radio Shack? Also what antanea set up would work good. I was thinking like a 20ft whip would be sweet. The fire stick I had on my last 710 did't work the best, even after tuning.
Thank for the help in advance.
CB Ideas
CB Ideas
Wimps Need Not Apply
I believe the older units are much more stable than the new stuff. I have run a Uniden pro 500 for many years with no problems. One of the members put a new Uniden 550 in his truck which lasted about a month. I found an old realistic on Ebay for $10.00 that has been working fine in the Pinz for a couple years now. I have the 102" whip antenna which causes me some problems, contact with the metal top. I also had the fire stick which did not do well in the truck. The biggest thing is to get the antenna above the truck, must be why they put the antenna mount on top. Most of the members have had great success with the cheap magnetic mount antennas. When the low branches hit them they just simply fall over instead of breaking off.
