Well I found some serious rust on my Pinz, Heat shield for the muffler. Would like to purchase a new heat shield but would like to find one made of stainless steel.
Miles
Anyone offering a stainless heat shield for the muffler
You could have the best of both worlds here! Lots of snow to play in (usually). Still a dry climate though over all and they use NO SALT here. You see very little rust here surprisingly.mjnims wrote:I guess we get spioled living in AZ. I don't understand all the need for SS products on the Pinz. A lot of money that is not needed here. The down side is it is difficult to find snow to play in. I guess you have to take the good with the bad.
Of course those -20 stretches can kind of stink.
Yeah I live in the desert too but the Pinz doesn't want to stay here, I plan on going to many diffrent locations and enviroments, Alaska is on the list. I have found very little rust on my Pinz, but the two major areas that it showed up was rusted through.
The muffler heat shield is subjected to a lot of heat and water so I want to only have to replace it once, with minimal mantinence required. The other area was at the top edge of the metal gas tank protector. Guessing it was improperly sealed with paint plus it's just a water trap at that seam.
Just a note the body is coming off next week so I can start on the hard top. I've decided on aluminum side and rear panels, with a fiberglass wrapped foam top. Hoping that will keep the heat down in the back bed area. The cab will stay a soft top configuration.
Miles
Miles
'73 Pinzgauer 712M
'73 Pinzgauer 712M
Well, having grown up in the dry deserts of Idaho I can relate to "little rust".
Moving to the Puget Sound and an island in the middle of it changed my whole outlook. We are lucky to have three months in which the humidity drops to below 50%! The "R" word has two connotations, rain and rust. Of course the ocean humidity with the "S" component doesn't help. Around here if you want a quickly destroyed piece of any machine just leave it in the out of doors! Give it a roof and you can add a few years but you have to look for un-painted steel all the time...sigh. S.S. makes sense around here and I use a lot of fasteners made of it along with lots of Rust Bullet and paint.
1975 710M
Mark...I will post as I can, still have some research to do on materials and techniques of manufacture. This is where my thoughts are in theory.
Miles
Miles
'73 Pinzgauer 712M
'73 Pinzgauer 712M
