Paratrooper wrote:
I have the option of getting an older pick up with 4X4 and doing a bunch of trick stuff with knowledge that parts are , in worst case scenario , on another truck at the salvage yard which will require me climbing under and removing
You need to factor in the cost to get front & rear lockers, probably gears if your uping your tire size. Easily $1500 - $2000 per axle.
Then you still have to tackle the suspension. It is very hard to get the ground clearance of the pinz and still have decent street manners on conventional 4x4. Even if you install it yourself, you are looking at $500-1000 minimum for a decent spring/lift kit, more if you are dealing with an independent suspension.
Once you do all that, you still do not have a pinzgauer. Trust me, with multiple 4x4's in the past, including two very capable FJ-55 landcruisers, a box stock pinz can give most modified 4x4's a very good run for the money.
So you can buy lot's of pinz parts for what it would cost to get a jeep or pickup close to the pinz capability range. And it still won't be a pinz.
Meanwhile, most routine items on the pinz are quite reasonable. Many of us have done civilian plug/wire/coil conversions for under $50. You can too, if your dist cap is in decent shape. Filters are widely available, etc.
Even pinz specific parts are not unreasonable when compared to anything but $100 junkyard TH400's. Go buy a 4 or 5 speed tranny for a civilian 4x4, and you are in the range of what rebuilt pinz trannies cost.
Steering box rebuild kit on ebay right now for $149. Shocks are reasonable.
transfer case & diff repairs can get expensive, but most of us have not had to deal with that, and it's still cheaper than adding lockers, gears, etc to Dana's if you pay a shop to do the work.
For an all around vehicle, that you would drive on the street, then take off-road, it's very hard to beat a pinz. Use it like a pickup and carry a full ton, then flip the seats up and carry 8 passengers. Canvas up or down.
Add EFI & distributorless ignition, and it's even better yet. I love the factory engine, and really feel the whole vehicle design just works well. To the point that I get in other 4x4's and just have no interest. Even the rock crawling trailer queens. So specialized I can't get interested. I have more fun loading kids & camping gear in the pinz, driving as far as needed, offroad hard, then drive home. You won't want to do that in most heavily modified conventional 4x4's.
Just a data point.... probably not a surprise since it's a pinz board. But I've had mine since 2000 or so, and would never go back to a conventional 4x4. (I do have 3 other 4x4's at the house plus the pinz for the kids & daily driving)
Have fun,
Alan
