This is why I needed the trailer info.
Nothing like caroling in while being towed behind a Pinzgauer.
Merry Christmas
Merry Christmas
I thought the peppermint lights would be enough. Until I called the neighborhood cop and asked what he thought.
Never the less he made the suggestion better at least make sure the trailer lights work so that wouldn't be on the ticket.
Still made it home with out a ticket. just made everyone get out and get in the back of the pinz, before we crossed any major streets.
Now that you have time and to avoid troubles in the future you need to acquire these
http://www.pinzgauer.com/showdetails.ph ... no=SAV1004
http://ecx.images-amazon.com/images/I/5 ... AA280_.jpg
and a couple 24v light bulbs. This is assuming you have already converted to the 2"sq receiver hitch, if not shame on you:)
I can tow any trailer I am comfortable towing with this setup, no need for special wiring connectors or any of that BS.
4x4Pinz,
That connector sold by SAV is the same as used by Range Rover, only prewired for the typical flat 4 trailer connector( though more money). A fast plug and go for the less electrical inclined.
And as far the wiring connectors BS. I have 9 vehicles of different eras and makes with 4 different sockets and 6 trailers with 3 different connectors. These adapters make it easy to move the different trailers with any of my vehicles, at any time. The magnetic lamps are fine for most trailers,but they don't stick to aluminum and trailers without a flat surface.
I have been on several MV boards and solve trailering problems for different vehicles and trailers in a permanent fashion without devaluing either, yours is only good for a Swiss Pinz. Many here tow their trailers with more than just a Pinz.
