Yes, I do realize putting stock in a Pinzy's visual nuances is utterly ludicrous.
Besides the weight and size probably being way too much, the VW diesels are high rpm (4500 +) compared to the 12v that were govern to around 2600 +/- rpm... it does make me think that you should be able to fit a 12V Cummins in there though...
David Dunn wrote:The engine bay is the same on all of them. The changes and extension of the shroud is from the radiator on the P90 being larger and in front of the tunnel . The P80 radiator is in the tunnel. The P93 has the innercooler mounted in front of the radiator.
Profpinz wrote:
If you fitted the larger P93 Shroud to a P80 or P90 so you could fit a functional intercooler you would need to make substantial modifications.
