Fuel injection revisited
Post by Jim LaGuardia »
Well, my EFI install on my truck is going well and it should be running by tommorrow night 8)
Here's a few of pic's of the progress:
I used the old coil bracket to mount the fuel pump.
Well, time to sleep :shock:
Cheers, Jim LaGuardia
"Arch Magus of Machines."
Rule 308
Post by Rule 308 »
Looking good Jim. I see you made that intake manifold see things your way. You mentioned that you were going to run pre and post fuel filter, I take it that cheese-dick :shock: plastic filter is on the suction side of that pump? It was good b.s.ing with you yesterday, I appreciate the tool loan and the tour of your F.I. set up.
Mark
Rule .308
I couldn't find a metal 5/16' fuel filter at 11:30 last night anywhere :shock:
That will get changed out as soon as I get to Napa(they close at 6pm on sundays) :cry:
It's ALIVE :!: Image
Just a few wires to tidy up, then off to the dyno :roll:
Profpinz
Post by Profpinz »
Nice job Jim.....I'm following all the fuel-injection discussions (both here and elsewhere with interest) as it's going to be one of the first jobs I get onto after I finish my new workshop.
BTW....LOVELY TIG welding on the components!
1997, 718 6X6 Pinzgauer
EuroPinz
Post by EuroPinz »
Wow JIM - what a great job!!
I myself (from Europe) am following this topic very closely and hope that you will come to a fantastic result, maybe even better gas mileage. Your pictures look great too. Here in Europe gasoline prices are starting to become a burden at over $ 5.00/gallon. I might become one of your first customers for this setup - of course I will need the kit as it would be a bit expensive to send the entire Pinz 712 to the USA. Otherwise, I might have the first electric powered Pinz 712.
MASSIVE PINZ
Post by MASSIVE PINZ »
Great job...
I have chose to mount the injectors for my set up in a different location, much closer to the cylinder head to reduce the effects iof fuel falling from suspension at lower RPM. My injectors are installed into the manifold and there is no fuel rail needed with the weld in adaptors that we have made to allow this.
I have now went through 5 different sizes of plenum and 4 different T/B sizes, the results have been very odd compared to what I have witnessed with other engines I have manipulated with EFI. Its my belief that this is due to the Pinz camshaft particulars with its very tight lobe center lines...
Jim, that looks like a 55 or 60mm T/B- what is it?? Do you know how much volume your plenum has? It will be nice to see some comparisons when I get my system dialed in and fully developed.
Then it's time to start all over again for the 3.3L beast :-)
Jake Raby
Owner, Raby's Aircooled Technology
www.aircooledtechnology.com
The Throttle body is 60mm off a ford 4.6L modular engine(92-95 T bird or Lincoln town car). I'll be getting it to the dyno next week as I have the dreaded jury duty the rest of the week :shock:
Hey Jake can you re-post fan balance info and where to send them?, I can't find a mailing address on your website.
MASSIVE PINZ
The address is under "Contact us"
But here it is
Raby Enterprises Inc
47 Raby Dr.
Cleveland GA
30528
Jake Raby
Locked
