OOOPS
I wonder if the wheel came off before, or during the roll-over?
It's probably a good time to remind people to keep a check on the wheel nuts .... because of the drive-train design and hence the strange resultant loadings on the wheels during suspension movement, the nuts can work loose over time!
I once had a wheel pass me on a bush track ....only to find a few seconds later it was one of mine!
(fortunately it was a centre wheel so I still had a wheel in the corner)
The real bummer was not loosing the wheel so much, but the brake drum as well, so I lost braking
Still we found most of the bits and we were on our way a little while later!
http://www.ozpinz.com
Hey you folks.
This is a more frequent occurance than you might imagine, The lost wheel mostly affects the drivers front from our experiences
To give you an example we had a few years ago a customer call us from Montana to say he had a strange noise coming from the truck. Since he was visiting family in Denver he would bring the truck by for a "look see".
When it arrived a glance around the truck showed everything looked fine. I told John to jump in and let's take thrash up the road and see what all this noise was about!
At about 60 mph flat scat, I said hey "this sounds like loose wheel! . In the next moment the front wheel took off like a rocket and us skidding down the road. Luckily I had the brakes on so the drum didn't take a trip with the wheel. Having found the wheel in a nearby field we stuffed it all back together , found some new nuts in the shop and returned the truck to the customer "fixed".
From that day to this shop policy is "We always torque all wheels after a "wheel off repair" road test the truck and retorque before delivering to the customer. A retorque is loosen the nut 1/4 turn and retighten. That's with anti seize compound on threads and cones.
The strange thing is that the owner drove the truck with a loose wheel all the way into Denver without a mishap until we got our hands on it.
So beware and as Peter has mentioned check the torque regularly. Usually you can see evidence of grease/rust bleed off the cones when the wheel is loose, but in this case we saw nothing!
Food for thought.
Dennis
Food for thought.
Dennis
OOOps no customer bashing now
I too hope that everyone is ok.
Makes me feel fortunate that my oops was at a lower speed and I just flopped over on the side instead of rolling. However I suspect that there is more damage there then initially meets the eye. At my slow speed oops I twisted the truck body out of align by nearly 2". latches had to be shimmed and I still have a 1 1/2 inch gap between my door frame and the rear of the drivers door window. chilly on a brisk morning.
The insurance company totaled it and I bought it back. I have toyed witht the thought of replasing the body but I think I will drive it as is for now
Rich A.
Rich A.
Yup that's mine!
As you all have noticed and may have read elsewhere I had taken all four wheels and brake drums off to pressure wash them after doing some wheeling in the mud and sand of central Florida.
Didn't get those left front lug nuts quite tight enough though. lost the whel at 105Kph hit the median almost immediately after that and rolled three and a half times. Got a big scratch on my head from my cap, but aside from that and some bruises I was fine. Still haven't found the wheel and tire though.
There are several more pics over on the Steel Soldiers site under the Pinzgauer section. I will probably slowly rebuild the top section and get it back into shape.
Chuck
Chuck
'74 710M Wrecked/Rolled
"The Worm"
'76 712M
718 Turbo Diesel
"The Worm"
'76 712M
718 Turbo Diesel
