breaks or that there lack of
hey all went wheelin this weekend and lost pretty much all my brakes on my 712 (kinda sudden) the pedal goes just about to the floor before it attempts to do anything if i pump it up i can get enough pedal to slow down but not to stop there doesnt seem to be any fluid loss in the resovoir like the master cylinder went anysugestions Thanks
It is only air and fuel ...For every 1 lb boost will gain you 10 % displacement
Sounds like you either have a slow leak somewhere in the lines, or you have some air. Can you pump them back up?TurboJim wrote:i went wheelin and started with great breaks and 6 hours later had none pedal to the floormjnims wrote:I check the brake adjustment every other oil change. Seems to work for me.
Since you have adjusted them already, try bleeding all corners and while there check for any evidence of previous leakage such as peeling paint, or more obviously, a damp area.
Good luck!
Check the master cylinder inner surface.
I had same issue on my old Range rover maybe 15 years ago. Usually it worked, but could suddenly drop without oil loss or air in the system. I almost got killed on the mountain road. Clue was bad inner surface where piston could not seal properly.
Bought a new master cylinder then.
Roman
Roman
1976- 710 M + 1976- 710MS
