Bead locks...again
Bead locks...again
I was bumping around the net today at lunch and I came across an article on Pirate4x4.com about something called the Rockstomper beadlock. The article is in their tech section for 2002. Also went to Rockstomper.com, looks like an interesting way to go especially since it apparently can increase the rim width. Anybody heard of it?
That looks like a conventional mechanical beadlock. One problem is that that style beadlock only locks the outer bead, which is adequate most of the time, but not all of the time.
Here is one big difference, on the page:
http://www.rockstomper.com/catalog/wheels/beadlocks.htm
-Evan
The Staun beadlocks allow for about 50 PSI or so. I do enough on-road driving that I would not want to be limited to 20 PSI.We recommend that beadlock wheels not be inflated above 20psi
-Evan
Another alternative, double beadlocks:
http://www.pirate4x4.com/tech/billavist ... mmer_Rims/
I had these made for my 712, and they are bulletproof. I went this route due to some rock damage to my stock wheels in Moab, and due to being able to air down really low.
Advantages: 8.25" wide (wider than stock but not outrageously so) made to my specs, custom outside rock rings (no chance of outside rim damage, two piece wheels (can repair if needed in the field), and ability to air down to an amazing 5 lbs without losing a bead. Also, surplus Hummer wheels and parts are cheap and plentiful.
Disadvantages: heavier than stock(price for indestructability), limited selection of 16.5" tires (plenty of WIDE tires, but limited that will fit the Pinze front), and necessity of switching out stock wheel lugs for longer ones.
I dont have access to pix this moment, but can share a few if anyone is interested. Dean, the wheelmaker is fantastic to work with.
Michael, Yes please would you share pic's? and were you had the adapters made.michaelh712 wrote:Another alternative, double beadlocks:
NICE
Nice rims Buck!
Where did those come from???
G
G
Eric,
no "adaptors." Dean cuts out the original hummer center piece, the flat part that mates with the drum. He then welds in a new mounting surface (heavier spec, with or without cutoutrs), and to your order backspacing. Wheels mount like original, without any additional adaptors, etc.\ I ordered original backspacing.
Plate that mounts to drum is therefore thicker (stronger), therefore the need for longer studs.
Only Other disadvantage I've experienced: slower drag race speeds from 0-60 (like, who cares), and possible increased need to change hub seals more often.
Life is full of trades
doesn't everyone have a 56" screen here?
i'll go resize those after work. wait, i hafta suck the sludge outa my lockers... and find an unattached baster 1st.
1973 710m
