Loss of Power: 710K
- mockingbird812
Loss of Power: 710K
I have a significant loss of power that developed rather quickly (w/i 2 to 3 days). It feels like it is running on 75% of availalble cylinders. I also have alot of backfiring in between shifts. Exhaust smells pretty gasoline-ish - not overpowering, but I think it smells like there is some unburnt gas in the exhaust. To cover the bases, I r/r the fuel filter with no change. I have the original distributor and shielded wiring, but have the Pertronix ignition system installed. BTW, what is the spark plug removing procedure? Special tool? I did a search on this last one but did not see any thing.
Thanks.
Thanks.
Sam
'71 710K
'71 710K
Sam,
To remove the plug wire, use the open ended wrench and unscrew the wire from the top of the plug. IIRC, it's a 21 mm. You obviously can't get the wrench on straight, sort of just reach in and turn. Mine were not on tight at all.
Once the wire is off, use the long tubular socket to remove the plug, as normal. The same wrench you used to remove the wire is used to turn the tubular socket.
- mockingbird812
- mockingbird812
I pulled the plugs (thanks for the tip - I am ashamed to say I have never worked with this type of shielded ignition wire system, but what's worse is, I have never checked my plugs ) and all but one are pretty fouled. I was surprised to see that all of my bosch plugs are set at approx 35 to 40 thousandths and my manual states .6 to .7 mms which I calculate to be approx 20 to 30 thousandths.
BTW, my Bosch plugs are WC8DC 366.
Sam
'71 710K
'71 710K
- mockingbird812
Regapped to 38 thou and checked for spark at each plug. Put it back to gether and my power has returned with no sign of backfiring. Gonna check my carburetion as i may be losing some power there as well. But, overall she is running fine.
Thanks for your inputs. If I want to convert my shielded ignition system to a standard system what recommendations for a:
1. Coil
2. Distributor
3. Wires
4. Plugs
5. Electronic Ignition
Thanks!
1. Coil
2. Distributor
3. Wires
4. Plugs
Thanks!
Sam
'71 710K
'71 710K
Try this
Do a search on here for the conversion - I know there is a step by step process out there... went and looked for it, and found it....
here.. >>.... http://www.sdp-pinzgauer.org/
Go to Technical Section ~ 710-712 ~ Engine
That is another good site for info. BUT this site (real4x4) is great for the info as well!
Pinzing is AWESOME.
My problems with plugs fouling were caused more by defective carburator float valves. The constant dripping of excess fuel generated a lot of gunk. Another symptom was, at times, a high idle caused by the rich fuel.
Just as one of those routine Pinzgauer checkup items, have you verified that the accelerator pump spigots in the carburator throats don't drip when you shut the engine off?
-Evan
-Evan
- mockingbird812
