water fording and snorkel
can you guys with snorkels do an update if you have any new info and pictures ? much appreciated i want to consider this on my 710m thanks guys.
710M 1972
710k 1974
710k 1974
Re: water fording and snorkel
Here are a few picture of what I did. Ill try to take some shots on how I ran the hose from the engine bay up and out. I used 2 ¾ id high temp hose from mcmaster part # 5499K245. I had to make a reducer sleeve at the junction where it meets the 62mm air filter inlet at the filter housing. The hose ended up exactly 5 feet long.
Photo Jun 16, 6 15 10 PM by bernhard Leitner, on Flickr
Photo Jun 16, 5 31 46 PM by bernhard Leitner, on Flickr
Photo Jun 16, 6 03 38 PM by bernhard Leitner, on Flickr
Bernhard
1973 712M
1975 710K
2013 Tacoma TRD 4X4
1973 712M
1975 710K
2013 Tacoma TRD 4X4
Check out Prof Pinz in the land down under. He has an excellent snorkel and the arrangement looks to be
a first class job.
a first class job.
Here are a few more pics. I don’t have any of what it looks like inside the dog house but the filter housing is in the exact same location. The hose connects directly to the intake with the hot air mixer removed.
Photo Jul 25, 4 43 03 PM by bernhard Leitner, on Flickr
Photo Jul 25, 4 42 42 PM by bernhard Leitner, on Flickr
Photo Jul 25, 4 42 33 PM by bernhard Leitner, on Flickr
Photo Jul 25, 4 41 49 PM by bernhard Leitner, on Flickr
Bernhard
1973 712M
1975 710K
2013 Tacoma TRD 4X4
1973 712M
1975 710K
2013 Tacoma TRD 4X4
Bernhard,
Where did you get the black grill/plenum parts?
I made that part. Unfortunately they are cost prohibitive to produce so I only made 2 sets. At one point in time the factory TD inlet was available for sale but have had no luck tracking it down.
Bernhard
1973 712M
1975 710K
2013 Tacoma TRD 4X4
1973 712M
1975 710K
2013 Tacoma TRD 4X4
Well, you sure made them look nice!
I had found the Steyr part numbers in another post, and wondered whether yours were factory and maybe available. Nicely done.
WOW thats awesome ! great design thanks for posting.
710M 1972
710k 1974
710k 1974
- McCall Pinz
I have the factory TD snorkel and Bernhard's looks like the better solution. They were available through Gut automobile for about $200 a few years ago, but with the swiss franc going up its probably about $300 if you can find an original one. The factory snorkel runs toward the rear, down the side, and then turns and goes through the firewall. The stock airfilter is turned 180 degrees and the thermostat removed. I haven't figured out how (or if) to reinstall the cargo grill behind the passenger with it. You can see it the thread about "show me your box"
eat, sleep, Pinzgauer
@bernhard:
just be careful with this type of hose. If it rubs anywhere it won't take too long to fail. And believe me it does rub at least on the air
filter housing or on the Platform itself.
I did it the same way you did. The problem is that you will not find out it failed till you are in deep water.
Now don't ask me how I found out.
For the others:
Here is the original TD snorkel. I didn't use it because my cargo grill was in the way and I didn't want to remove it.
This is what I came out for my 710m. Left is the original Austrian Army Antenna Base. On the right side of the vehicle you can see
the Snorkel. At least I didn't have to cut new holes into the roll bar.
Richard
For the others:
Richard
- audiocontr
First thing i notice are the door handles. Have difficulties closing the door without them?
Nice work on the snorkel! very jealous!
Some of us have notched the window frame for the door handles so the door tops can be removed without first having to remove the door handles.audiocontr wrote:First thing i notice are the door handles. Have difficulties closing the door without them?
- audiocontr
which i will now do as well!!!!
- David Dunn
The bend is part of the structural rigidity of the door upper. Notching it makes the upper weaker than they already were. SDP had added a radius to the window corners to try to combat the sheetmetal from tearing there.edzz wrote: Some of us have notched the window frame for the door handles so the door tops can be removed without first having to remove the door handles.
SDP revamped the uppers entirely on the TDs, using extruded aluminum for the frame and heavy steel angles for the corners and attachment to the door lowers
I used t nuts on my old 710 and 712 to attach the handles to the uppers ( and they came off with the windows)...the whole top edge of the door can serve as a handle.... unless you're afraid of putting fingerprints on your pristine paint
David, I never said anything about cutting into the radius. Honestly don’t believe cleanly notching for the door handles has any detrimental effect on the structural integrity of the upper door halves. Mind you I only have ~20 years in aerospace structural manufacturing, refit and repair. I will agree that if the notches not done properly you would be creating potential problems, remove a minimum of metal and radius corners of notches.
