Slipping out of low gear range
Hello All,
My c303 worked just fine until I am all of a sudden have a hard time engaging low gear range, meaning it stays in neutral, unengaged until I go back to high range gearing. Sometimes, I'll get it to engage in low gear range and it slips out the moment I am accelerating in first gear. Any ideas?
Thank you!
Marcus
Thank you!
Marcus
Re: Slipping out of low gear range
Perhaps the shift linkage is adjusted a bit too mutch toward the high range side. Low........Neutral...High I had similer prob getting into low when I got mine,a little adjust and all fine!
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
68 Haffy
Thanks for replying to my post although its Thanksgiving. Do you have a reference for directions on how to adjust the linkage?
Marcus
Marcus
Get a helper,look thru the dog house cover,see which way the llinkage goes, adj (threaded linkage),if it's better,keep going until happy,if worse,well,go the other way. Sorry for the late response,been real busy...
Mark
Mark
68 Haffy
68 Haffy
Will give it a try. Thank you.
Marcus, please post location and vehicle model in your profile. :idea:
thanks
I went to a local Volvo dealership here in Denver and the shop foreman is comfortable working on my toy. The gear issue was caused by the parking break cable blocking the linkage to the auxilliary gear box...a 5 minute fix for free.
