26 March 2016
First task connect the Powersteering inspection reveals the banjo bolt is missing hmmmmmmmmmm I
know just the shop. A quick run down to the parts street gets me the parts I need 8mm 12mm and
10mm hoses and connectors etc
Then the task of fitting the turbo water inlet. Since we had to chop the top of the thermostat
housing off which contained the turbo cooling inlet and outlet taps. We have a donor location
from the left side of the engine unfortunately. Worked it all out another trip to the hydraulic
shop and the same assistant lol.
On the way back I drop into a chop shop collect 12 military boxes and 6 special ones. Reveal on
these later and also pickup a diesel filter and housing as this was missing from the engine
when I bought it.
More puppy damage a new scraper destroyed before I even used it.
Then the arduous task of removing the broken sump bolt. Drill it out then try and find the
eaziouts I bought in the morning. Searched for ages could not find. In frustration I climb the
office stairs and then spy a pile of rubbish near the Landrover and investigate yes the eazi
out packaging destroyed along with the plastic case.
Recover the eazi outs and finally have the errant bolt out. Victory finally. Now sump can have
the oil temp sender fitted and fit it back.
Turbo cooling hoses connected. The turbo shielding needs work. Will install this one and build
another fancier one out of alloy in coming weeks as this one has transport damage.
The left side of the engine almost completed change al of the vacccum hoses to new blue silicon
until I ran out more needed. Only 2 pipes need sorting out still. Power teering pump hoses all
connected - mounts to cabin but that may change soon as engine needs to drop out as a complete
unit from the cabin.
Hometime 7.15pm and long horrid drive home ensures in the dark. The brakes stink by the time I
get to the restaurant in KL by 9pm from the heavy braking from 150-170kph constantly.
Next visit we will be changing the wiring loom to split it with a military plug at the cabin
and hopefully filling the engine with oil and starting it. Well it's the goal.
The consoles may also be cut and eady for test fit. The dash's will also be fitted and the air cond parts.
