Soft top cleaning
Posted: Wed Apr 05, 2017 9:55 am
by Sonarman
I used 303 fabric cleaner, it is actually a multi surface cleaner. While it did not get it perfectly clean it did a pretty good job. I also use a pressure washer to rinse the cleaner and dirt out of fabric with the pressure dialed down.
Re: Soft top cleaning
Posted: Wed Apr 05, 2017 11:53 am
Not bad!
I have used a pro steam cleaning machine before with great results
Posted: Wed Apr 05, 2017 12:51 pm
by Heinkeljb
Only issue you have using a steam cleaner is that you have to re-proof again if you are cleaning a canvas top. If it is plastic, then you run the risk of melting a hole in it when you get a stubborn spot!
John
Posted: Wed Apr 05, 2017 9:34 pm
by Rookie
What do u use to re proof
Posted: Thu Apr 06, 2017 8:15 pm
by Sonarman
After the soft top completely dried, I coated it with 303 fabric guard. Probably 28 ounces of it.
I also coated some cushions on the deck with the fabric guard, forgot to put them away and the rain came down pretty hard. Pretty good water repellant I hope the UV protection is as good!
Posted: Fri Apr 07, 2017 8:19 am
I have used this with very good results
http://www.marlentextiles.com/aqua-tite-green.html
Posted: Sun Sep 10, 2017 4:40 pm
by krick3tt
I had the original type top and every year I would take it off, spread it in the driveway (after washing the concrete) and brush it with dish soap, hose it off and then spray it with 303. Kept it looking good for ten years.
Posted: Mon Sep 11, 2017 5:51 pm
by rmel
The that cover on my 710K gets a pressure washing every few years which gets all the
green slime out. Followed by an application of Trek7 or your favorite repellent does the
trick for me.
No, she's not covered now :wink:
