Can someone tell me what the function of this is?
Posted: Sat Jun 08, 2024 2:40 pm
by critter
Small box with bayonet plug in front of the ignition coil. Upper right of the wind tunnel. Has a 4 wire plug going to it. What does it do?[img][attachment=0]IMG_3214.jpg[/attachment][/img]
Re: Can someone tell me what the function of this is?
Posted: Sat Jun 08, 2024 2:41 pm
by Tyler
critter wrote:Small box with bayonet plug in front of the ignition coil. Upper right of the wind tunnel. Has a 4 wire plug going to it. What does it do?
Your image didnt upload, if you had one.
Posted: Sat Jun 08, 2024 5:01 pm
by rmel
Voltage regulator,
https://expedition-imports.com/voltage- ... n-eic2606/
If it's not connected you must be running with an alternaotr with a built in regulator.
Posted: Sun Jun 09, 2024 6:07 am
by critter
Thanks for your reply. One of the wires, Dark Blue, broke off the connector. The regulator seems to be original. I also see the plug is no longer available at SAV.
Bob
Posted: Sun Jun 09, 2024 9:13 am
by rmel
Blue is the D+ output from the alternator to the regulator.
If it's not connected your regulator will overdrive the alternator.
You can just replace the connector with individual "FastOn" connectors.
For that wire gauge "Blue" 0.25"will do the trick
https://www.amazon.com/Conext-Link-QDVF ... =1-19&th=1
Use a decent crimp tool.
https://www.amazon.com/Haisstronica-Ele ... r=1-4&th=1
Posted: Sun Jun 09, 2024 3:31 pm
by critter
Electrical has never been my strong suit. I am not sure how old that voltage regulator is but it looks original. 50 years. I think it may be time to replace it also.
Thanks again. I appreciate the info.
Bob J
