Phillip,
Yes, I know of the material you mentioned as I believe its used by the
folks at Earthroamer:
http://www.earthroamer.com/main_truck/v ... cture.html
We will make the mould plug (basic shape) in our workshop and I have
lined up a boat builder to make the mould and produce the first shell in the GRP/foam laminate material, which he uses extensively in his (£1.5m!) yachts.
As for carbon fibre, he's recommended using a stranded version for structural reinforcement in those areas where we've traditionally fitted steel tubing roll cages...same strength for minimal weight, but we will still incorporate a main hoop for the cab occupants (having been grateful for them quite often in the past!).
Power steering will be a development made easier if we do use a Rover V8 as they come with power steering pump fitted - are you aware of a power steering box that fits the C3 installation?
However, with a vast reduction in vehicle weight and the use of modern radials the need for power steering may be significantly reduced.
I'm a great believer in the 'Keep It Simple' development school, wasn't it Boss Kettering that said "parts left out cause no service problems" (rough quote).
Cooling - If we do use the all-aluminium-alloy Rover V8 (thanks for giving us one of the greatest engines the UK has ever had Buick!) cooling will not be a problem, even with a std. rad as these engine run very cool as the heat dissipation is excellent, but we will fit the 3" rad as a matter of course because the application will include plenty of slow speed (eg desert) clambering around.
Roy
