The problem is my brake light now remains lit. Brakes function perfectly, no pulling, no squealing, no grabbing, but even when I disengage the parking brake, the light stays lit. Previously when I disengaged the parking brake the light would go out. I'm only guessing here, but it seems that I had a similar problem with my 1967 Ford Falcon many years ago, when I bled the brake system on that. As I recall with the Ford, the problem was the little ball in the proportional valve was no longer centered, thereby causing the sensor to activate the brake light. Would anyone like to comment on the problem I'm having with the Volvo? Does it sound like the same problem? I did remove the sensor wire yesterday afternoon and reinstalled it to see if maybe it wasn't making connection, but the light remains lit. And lastly- how does one make the necessary adjustments to rectify this?
Thank you!
-Scott
