Floor Vent
floor vents
Erik,
That's it...or rather, that's them.
Now, where to get them.
Those are what LR and others use to use....this is one used by horse trailers
http://www.horsetraileraccessorystore.com/vents.htm
We call them Russian airconditioning as the air comes Russian in
But I think they are great (until my aircon is fitted). The outer ridge is spot welded in 'I think' and the door is bolted to that frame and spring loaded. As Dave was saying was optional for us hot placed people.
http://lightweightlandroverclub.org/php ... d=1784&f=5
I can get some inner and outer photos plus 'maybe' see if theres any on a rolled one I know of
Regards
(Project Gimpy 2)
(Project Gimpy 2)
The is quite a steep hill behind our workshop that I terrify passengers on. However had one who said can you go steeper so I guess it was rather steep as the winch got slightly dirtyErik712m wrote:Mike what in the heck did you dig into? Bright red balls are?
The red balls are the winch terminal covers, never fear I didn't dig up the strawberry patch
Regards
(Project Gimpy 2)
(Project Gimpy 2)
That second link- nice! best example of expedition rig...
Saw that one on the big european overland expo site-
IMHO best set up to copy-
I especially like the side gas tanks set on rub rails, instead of putting more weight on top or back- less pitch and roll that way.
ABSOLUTSECURITY
These are the ones going into the Pinz next - you might send Scott at EI an email showing these pics - I'm sure Scott can get you them..
G
Glynn Sziraki
www.ownnight.com
1975 712 AMB-S
1996 AM GENERAL HMCS H1
1972 SUZUKI LJ10
1985 HONDA FL350R ODYSSEY
1990 HONDA FL400R PILOT
www.ownnight.com
1975 712 AMB-S
1972 SUZUKI LJ10
I used some vents from this company, lots of parts for step vans
[/url]http://www.rustrepair.com/stepvan_parts ... p=wi-vents [/url]
The ones I used V-648-AL are aluminum 5" x 10" outside and they open both ways
There is a handle on the back I removed (couple of rivets) and trimmed a tab back so they protrude about 2" inside the cab
I can give a push with my toe and it pops open or they can be opened or closed from the outside
Because they protrude inside you have to be careful where and how you cut the hole
The mastercylinder and brakelight switch are real close
I had to bend one of the brake lines a bit to clear and I modified the glove box as well
I have picts but no way to post them, if someone wants to Email me I will send them
Chris@harrisonautodynamics.com
ABSOLUTSECURITY
Those look nice - post some pics so we can see!
G
G
Glynn Sziraki
www.ownnight.com
1975 712 AMB-S
1972 SUZUKI LJ10
www.ownnight.com
1975 712 AMB-S
1972 SUZUKI LJ10
Pinzgauer Pete
Floor vent
Nice pics of the vents...wondering if the clearance inside prevented the correct mounting of the vent..by this I mean that the flange which has the securing rivets should be on the inside of the body, and a hole is cut to the size of the vent door, which is the only protruding part of the vent outside the body.
710M
710M
floor vents
Maybe they could be mounted in the forward part of the door? The flange could be inside then. Still get air into the cab mounted that way.
Still get ripped off with bushes and such.
When I take my doors off for desert travel, flow through air is not an issue.
edit: (see below) Good points Chris.
I mounted from outside mostly cause the hole does not need to be very nice
The vent has a nice wide flange that covers any errors (not me)
Clearance inside is tight but with the master cylinder out it could be done
Thru the door would pose some challenges with the inner panel and I think the mechanisms inside would eat a hole in my leg
Heck, the rivet that holds the door latch bucket wears on my knee after a couple of hours
Chris
Chris
Re: Floor Vent
They do work awesome, especially with the heat we have been having.
