Headlight bulb, base designation
Locked
milesdzyn
Post by milesdzyn »
What is the base style called for the original Pinz headlight bulb? H3?
Miles
EuroTruck
Post by EuroTruck »
The base is known as an P45t.
-Sean P.
EuroTruck Importers, LLC.
Odd-Ball Trucks and Parts
770-965-3311
www.eurotruck-importers.com
PinzEOD
Post by PinzEOD »
Hey Miles
I picked up a couple spares at The Lighthouse here in town. Hella Number 78161 (24v).
Mike Newton 1973 712M (sold)
milesdzyn
Post by milesdzyn »
Thanks Sean, Mike....I'm looking for something brighter than the stock, and that won't burnout really fast. I've though of making an adaptor so I can mount some HID units, since they are coming down in price. Super bright at 35w of draw. Plus they last a lot longer than standard halogens. I guess it would be cheaper to just upgrade to newer lenses though.
Miles
Profpinz
Post by Profpinz »
I opted to fit Hella Quartz Halogen Headlamp inserts with 100/55 globe inserts (12 volts in my case, but I see they are available in 24 volt 75/70 and 100/90) to replace the standard Pinny units.
I can give you the Hella Aussie Part No: but it probably won't help, but as the lights are made in Germany I'm sure they are available world-wide.
They have the parking light aperature fitted in the side, so slight modification of the original Pinzgauer / Bosch mount is need to clear the protruding parking light base, but it is minor.
I've broken a few of the lens/glasses over the years, but apart from that no problems and they provide more than enough light (especially when I switch on the HID equipped 4000's as well :wink: )
I originally fitted 130/90 inserts (non Hella) to the Headlamp inserts and while the extra light was great, the heat generated was even greater! :cry: .... the result was that when driving at night through deep water / mud the sudden submersion of the headlights cracked the lens.
This is not a problem since I went to the 100/55 inserts.
1997, 718 6X6 Pinzgauer
Locked
