Tires (again)
Tires (again)
Anyone ever used Q78 16's? I happen to have some and am getting ready to put them on. They are 35.5 tall and 10.8 wide. I think they should fit ok on my new ambulance/camper.
lock bolt?
What the hell is the lock bolt? It sounds like a big deal.
sounds bad
I measured them, fully inflated and they are right at 35 inches tall. I thought that prof pinz had 35.5's on his?
lindenengineering
I run 35" (according to the manufacturers specs they are 887mm / 34.9") ....They are actually Simex 35X10.5-16 ET's on stock Pinzgauer rims (the tyre's co-designer said they'd be OKI thought that prof pinz had 35.5's on his?
http://www.simex4x4.com/html/s02_articl ... =55&dsb=38
They do foul a little in extreme situations, something I intend to fix in the future with a slight accelerator linkage and steering box mod.
I originally had 34" Swampers but changed, not because I didn't like Swampers, but because they are VERY difficult to get here in Oz nowadays..... Swampers have virtually dissappeared off the Australian 4WD market!
I agree with the others, that fouling can be a major problem especially if it puts an intermittent / hammering force on the mechanical components (like the continual "clipping" of a lug etc) but like most things it can be fixed with $'s
1997, 718 6X6 Pinzgauer
Been there, done that. Except, the lock bolt didn't shear, the entire axle housing 'ripped' open as it spun around. Total carnage, in the boonies. Fortunately, being a 6 X 6, I took off the tire, pinched the torn brake line, pulled off the mangled shock, secured the axle as high as I could with some cable, and drove home 90+ miles, pondering repair costs the entire distance.Jim LaGuardia wrote:They will rub and twist off the lock bolt in the back if you are not carefull
Mike Newton 1973 712M (sold)
