24 Volt Pump
Locked
andy
24 Volt Pump
Post by andy »
I can't find the thread now, but it seems to me, sometime within the past two weeks or so, someone was asking Dennis about a pump or some such for a spraying rig. I dont remember the details, but Saturn Surplus has a 24 V pump that might fill your bill.
Scot, 24 VDC, Electric Pump Assembly.
Manufactured by Scot, Model #: 86, Part Number: 13217E7135, NSN: 4320-01-047-1927. Driven by a 24 VDC electric motor. Rated at 50 GPM @ 60' HD. Pump operates at 3, 450 rpm's with a 2" Inlet and 1 1/2" Outlet. Assembly weight: 111 lbs. Location: Bldg 5.
The above is the available information that came with the page. The part number might be theirs.
Hope that helps.
A bar F
The buck STARTS here
www.deerleaseservices.com
andy
Post by andy »
This should be the link or at least the address to view the pump.
http://saturnsurplus.com/miscpage/1927.htm
A bar F
IA712
Post by IA712 »
Thanks Andy, I was the one asking (on the other forum). I will have to check this out. Looks like it would work well for bulk transfer but will have to see if it can handle the backpressure of being used for a sprayer pump. Also will check into the power usage to make sure the Pinz electrical system can keep up with it.
Lloyd
PinzEOD
Post by PinzEOD »
Have you checked with Dultmeier Sales? They have a place in Davenport.
www.dultmeier.com
1-800-553-6975
I've used them for oddball stuff on some of our DOT spray rigs out here.
Mike Newton 1973 712M (sold)
Locked
