Fuel tank drain plug leak?
After letting my 710k sit for a couple years I'm getting it moving again. In the process I thought I'd drain the old gas from the tank by removing the drain plug. It was hard to free up and came loose with a loud bang. Once free it unscrewed smoothly. So smoothly that it dropped into the funnel I was using to catch the old gas. Boy does that gas flow fast! The plug hole is large. Too large to block with a finger. Good thing my son was able to go get a second gas can to catch the remainder of the gas. It was a tense few moments as I was drenched in gas and plenty was spilled on the ground.
Anyway, my question is now that I have fresh gas in the tank why isn't the plug sealing well. I have a slow drip even though I've tightened it pretty good. Do I need to replace a washer? Should I use teflon tape?
Thanks in advance, Tom
73 710K
those washers are designed to squash into shape on 1st install. after that they're pow. they also get hardened by that 1st squashing.
1973 710m
norcal pinz
Ditto the every-other-year draining. But I toss the old stuff into my deuce & 1/2, good or bad. That thing eats anything: old gas, fuel oil, deep-fry grease, old cats, anything! OK, it doesn't really run on old cats.
Still rather drive my Pinz, though. It smells better.
Paul
Sorry, I'm up too early.
Paul
