dont jump your pinz.
I'm pretty sure that the manual says not to jump your pinzgauer? but, the newer model pinzgauer, in the updated video catch a little air! my question is there anything you can do to modify the suspension so you can jump a little?
710M 1972
710k 1974
710k 1974
If the check straps were damaged or missing it could do damage in the diff (the axle casings could "intersect" with each other at the bottom of the diff housing) but otherwise I can't see any problem.....well no more than any other vehicle
http://www.ozpinz.com
