--Donnie
djb_rh wrote:Sorry, just figured out how to get MobileMe to let me embed images on the forum. Here's the one I want to get rid of:
And here's the new one with the 8274 installed on it:
I did replace the stainless winch rope with synthetic and those are poly rollers on the fairlead to protect the stainless rope. The lights aren't wired or adjusted yet. This one is at least as solid as the one pictured above, probably more so. It also doesn't protect as well, but I just wasn't as worried about that. Going lighter seemed better for my use.
The angle of the photo is bad...it does still allow for a lot of air into the motor compartment. Just doesn't look like it from here.
--Donnie
Just to point out. this set up probably weighs the same as the bumper Scott sells.locosmith wrote:Where did you get the one you've installed? I want a small one also, not sure of those big heavy ones..Loco
--Donnie
If so, it's only because it has to for supporting an 8274. I also think it's actually a lot stronger than the one Scott sells. All the force on Scott's while winching is transferred through a single tube torsionally (well, two...one on each side). I'm sure it works, but I like having the force going through a thick angle piece instead a lot better.Erik712m wrote:Just to point out. this set up probably weighs the same as the bumper Scott sells.
