Hi,
I have a CJ7 Jeep with Volvo portal axles and in Australia I find it hard to get parts and I am hoping someone can help me.
I am after CV boot, large outer oil seal for the stub axle and retaining nut for the stub axle and tie rod ends for a right hand drive.
Hopefully someone can point me in the right direction.
Thanks.
Parts for volvo C303 portal axles
lindenengineering
wrangler_tj
I also can arrange parts if needed.
In Belgium Volvo Trucks can get the parts if on stock.
The CV boot originally isn't good. You can get newer from online shops from wich the quality is better.
I recommend www.omt-offroad.com.
That's what I found:
http://www.volvo4x4.com/tech/parts/bearings/
Volvo c300 portal axle bearings/seals
bearings:
Drive gear (upper/small gear)
SKF/FAG 6210 (single row radial ball, open) - dims: 50x90x20
INA BK4520 (drawn cup closed needle bearing) - dims: 45x52x20
Driven gear (lower/large gear)
Timken JLM104948 (tapered roller/cone)
Timken JLM104910 (tapered race/cup)
Timken JLM508748 (tapered roller/cone)
Timken JLM508710 (tapered race/cup)
seals:
CR 23451 (STEFA, BB - dims:60x85x8), upper portal/axletube oil seal
CR 19687 (STEFA, BB - dims:50x90x10), inner hub grease/oil seal
STEFA, BY 80x92x28 (pn#32896 1) - outer hub grease seal --
*this is the impossible to find seal.
Also
http://www.freewebtown.com/adventures/miscellaneous.htm
bearings:
seals:
Also
