EFI
HafWit
Post by HafWit »
The excitement is building. I look forward to seeing the final result.
Greg
HafWit
M Wehrman
Post by M Wehrman »
MeeToo! I'm tired of inconsistancies w/my set-up! Have any pics of your Volvo?
Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
Post by Jim LaGuardia »
Mark, here are a few pic's of Greg's Mobile Fortress.
I will repack and ship your carbs back as you may want to do this mod.
Cheers, Jim LaGuardia
"Arch Magus of Machines."
M Wehrman
Post by M Wehrman »
And I thought my Pinz had a lot of tubing! I like the way the rub rails flow with the doors! Is it running yet?,is it running yet?
Mark
68 Haffy
It will run this week. I have to pick up a couple resistors to drop the starter signal voltage to 12v and a few other items to complete the fuel lines and ECU/Power supply mountings.
HafWit
Post by HafWit »
That isn't a lot of tubing....it is just the right amount :lol:
Jim, I am looking forward to seeing the albatross fly once again. That is assuming that you are willing to release it from around your neck.
Greg
HafWit
HafWit
Post by HafWit »
Jim,
How's the original Albatross coming along? I say original, since Andre's rig is now apparently known as Albatross II.
Greg
HafWit
I am picking up the main system 24v relay and resistor/voltage drop circuit parts for ECU start signal on monday.
I am currently installing the fuel supply and return lines.
Will get some pic's soon :D
HafWit
Post by HafWit »
Jim,
Wonderful news. My red Haflinger may soon be departing to go to a new owner. That will make room on the driveway for the Albatross I when you are done with it.
Greg
HafWit
M Wehrman
Post by M Wehrman »
Jim,I'm die'n here! :( This is worse than a "to be continued" on an A-Team episode! :P
Mark
68 Haffy
I hope to have it running by weekend.
But until then, here are a couple pics of the completed ECU center.
First image is the 24 to 12v starter signal circuit. It is 2 1K 1/4 watt resistors in series, one end is 24v signal, other end is ground(earth for the UK guys), 12v is tapped from between resistors to feed computer starting enrichment signal.
Harness access locations.
ECU Center ready to install.
ECU in place.
And one of the heat shield mod to fit TPS connector.
Carbs converted to throttle body with TPS
Enjoy more to come :twisted:
wrangler_tj
Post by wrangler_tj »
Fantastic! Looking forward to see MORE!
HafWit
Post by HafWit »
That looks great--a nice clean install. I'm looking forward to putting it to the test. In case anybody else didn't know this already, Jim does great work and I recommend him highly.
Greg
HafWit
Here are a few more pic's.
First one is starter signal resistor pack install point(black wire from starter to solenoid).
Next, remove drain plug from gas tank, install 1/4"NPT to 5/16" line fitting adaptor(use only LIQUID TEFLON SEALANT).
Bend and fit 5/16"return line
More to come..........................................................................
Fuel pump location/line routing for fuel supply and return.
