C30x transmission length?
Just wondering if someone has easy access to a tranny to measure the length from the front of the bellhousing to the transfer case mounting surface. Thanks.
Re: C30x transmission length?
Anyone? With the wealth of knowledge on this board somebody must know.
I'll get a measurement tommorrow.
Exactly 40cm from front of bell housing to transfer case mating surface
Thanks Jim! Just doing some research and that helps me out.Jim LaGuardia wrote:Exactly 40cm from front of bell housing to transfer case mating surface
Bell housing is 15cm, trans is 25mm from front mating surface to the transfer case mounting surface. Standard ZF gearbox size for that era.
