Handbrake assembly rebuild (in cab not brake itself)
Hi All, I am replacing the handbrake cable and have had a problem with the handbrake not staying on, it has to be pulled hard, then twisted vertical where it will sit for a moment or two, then spring off. Does anyone have an exploded diagram of the locking mechanism of the handbrake itself? It all came apart quite quickly and I didn't see how stuff went together... Thanks
Located in Geneva, Switzerland, 1979 710M Pinz
'Never underestimate a man who overestimates his own capabilities'
Re: Handbrake assembly rebuild (in cab not brake itself)
Maybe you can extrapolate something from this:
Sent from my iPhone
Sent from my iPhone
Thanks Berger, thats just the ticket, I can deduce whats going on from that! Cheers
...also, just a thought. When my handbrake lever (in cab) would not hold, I ordered the disks for the rear brake assembly as I had had it apart once and thought perhaps my rehabilitation of the parts was not successful.
Turns out that a few drops of oil on the shaft was all it needed. Not logical but it works now.
X2.krick3tt wrote:...also, just a thought. When my handbrake lever (in cab) would not hold, I ordered the disks for the rear brake assembly as I had had it apart once and thought perhaps my rehabilitation of the parts was not successful.
The same thing worked for me also when the lever wouldn't stay locked.
