So after many tribulations I finally got my door open so I could dismantle it and fix the broken lock.
Now I am stuck on how to get the lock cylinder out. The pictures below show the cylinder and the slim nut that holds it in. There is very little room. I tried to use some channel locks but can't get a purchase on it. What other tools might I try?
need suggestions for removing door lock cylinder
- Broken lock #2.jpg (793.45 KiB) Viewed 2637 times
- Broken lock #1.jpg (616.68 KiB) Viewed 2637 times
_________________
1977 Austrian 712K
http://www.swpinz.com
Facebook: Southwest Pinzgauer
1977 Austrian 712K
Re: need suggestions for removing door lock cylinder
Deep socket that fits over everything?
My locks were not overly tight and a small pair of channel lock pliers and patience did most of the work. If I remember correctly a 27mm open ended wrench got things started.
Good luck
Good luck
