Page 2 of 3
Posted: Thu Jan 04, 2007 5:39 pm
by Scooter
Kiwibru,
It was easy to do. I used the same wires and did not add anything additional. On the inner LED I did not connect the brake/turn wire only the tail. The real work was getting the box modified and re-painted. I tried keeping the new holes and wire holes to a minimum.
Scooter
Posted: Thu Jan 04, 2007 6:51 pm
by Kiwibru
Nice to hear Pinz and Scooter, thanks. I like simple and this makes it a much easier to do upgrade for me as I am no wire wizard and it takes me forever to do this kind of work. Much more a nuts and bolts guy I guess.
Posted: Fri Jan 05, 2007 2:51 pm
by Kiwibru
Denis, did you cut the holes (4 1/2") directly through the Pinz mud guard mounting plate? It looks like it and it certainly is a clean looking install. If so, what did you use to do the cutting, jig saw, sawz-all, other?
WELL HERE ARE MY NEW LED TAIL LIGHTS
Posted: Thu Jan 11, 2007 8:14 pm
by AK NIMROD
Image[/img]
RUNNING LIGHTS ON
FLASH WASHES THEM OUT SOME :cry: :x
Posted: Thu Jan 11, 2007 9:22 pm
by Scooter
Looks great, I see I used the same housing that you did.
My LEDs are almost too bright. But better seen than not seen.
Scooter
Posted: Fri Jan 12, 2007 5:18 am
by AK NIMROD
truck lite housing ....local shop had them and took original lights out and then i used my ASL LED lights, clear until on then red......not what i ordered but a pain and alot of time to return them. still working on aux. heater. getting pretty close to finished
Posted: Fri Jan 12, 2007 5:58 am
by Scooter
I used super brite lights from truck stuff.com and modified the housing to fit.
I put my aux heater in last year Webasto 2000. Big help this winter for the back end of my 710M.
Scooter
Posted: Fri Jan 12, 2007 1:52 pm
by AK NIMROD
we installed boxes upside down ( so they would be flush and less visable holes)and plugged drain holes and added paint as the only mods ASL LIGHTS fit without problem . have both doing all three functions
Posted: Sun Jun 24, 2007 8:58 pm
by AK NIMROD
UPDATE WELL ON MY TAIL LIGHT SYSTEM TWO OF 4 ASL LIGHTS FAILED COUPLE MONTHS AGO, REORDERED 4 RED USED TWO CLEAR AND TWO RED NOW 3-1/2 HAVE FAILED HAVE ONE RED WILL LIGHT IN 5 OF 12 LEDS :evil: :shock: WILL BE LOOKING FOR DIFFERENT LIGHTS THAN ASL. TWO REMAINING REDS INSTALLED TO KEEP ME ON THE ROAD.
Posted: Sun Jun 24, 2007 10:33 pm
by Scooter
How many hours before they started failing?
I have noticed that the tail light brightness is very close to the brake light brightness. It was hard to tell when the brake light goes on if all four were on as tail lights. I fixed this by having one light tail and the other brake/tuen only. This way you can see a different light come on for the brakes. Maybe it could be from the lack of a load on the system now that I have LED lights.
Scooter
Posted: Mon Jun 25, 2007 2:20 am
by AK NIMROD
HARD TO SAY BUT PROBABLY LESS THAN 50 WITH LIGHTS ON BUT I DON'T RUN WITH THEM ON ALL THE TIME AROUND TOWN.
Posted: Mon Jun 25, 2007 6:16 am
by Scooter
thanks, I'll have to do a safety check before I drive now.
Scooter
LED Lamps
Posted: Mon Jun 25, 2007 5:35 pm
by Wayne Roberts
I used the same housing as AK Nimrod but used the Trucklight Super 40 LED lamps in 24volt. They have continued to work flawlessly. They are designed to work on class 8 trucks and they are designed for excessive vibration. I have found that you get what you pay for when discussing lights. When I was a heavy truck mechanic, my shop would only use Trucklight and always had great luck with them. The Super 40 lamps have rubber mounted internals to provide a way for the vibration not to affect the lamps. They are not available in clear that turns to red though. Try a set of these lamps (available anywhere that heavy truck parts are sold) and I am sure that you will be pleased with the results.
Wayne
Posted: Mon Jun 25, 2007 9:30 pm
by Scooter
The ASL LED lights I bought were only a few bucks cheaper $90 for four and stocked. I could not find anyone local that the truck-lite ones in stock.
Scooter
Posted: Tue Jun 26, 2007 8:30 am
by PinzEOD
I, too, run the ASLs, two amber and two red. I have them mounted in rubber grommets in a home-fabbed box mounted over the stock light cutouts. I've had them more than two years with no problems whatsoever.
