Page 2 of 2
Re: E-trac
Posted: Fri Feb 25, 2011 1:17 am
by audiocontr
Winter Beater wrote:I did a similar install to Paul's and learned from his clearance problem. Used a 2x4 as a spacer on the bed (712M) and put E-trac on top; then used #14 Home depot self tapping screws (with rubber washer) to drill into uprights. Both sides 25 minutes - use a real drill with a cord.
Be careful of rust where you used those self tappers!
Re: E-Trac and seatbelts - NEED help! Mounting questions
Posted: Thu Mar 24, 2011 4:10 pm
by swashplate
Etrac= I used (2) 8 footers
http://www.uscargocontrol.com/Van-Trail ... -Tie-Downs
Seat belts=
http://www.expedition-imports.com/c=gzG ... -BELT.html
Grade 5 & 8 fasteners, Angle iron for brackets, Flat iron for stiffeners (home depot)
Will try to post up photos this weekend, weather permitting.
