Page 2 of 2
Posted: Sat Mar 13, 2010 1:07 pm
by ABSOLUTSECURITY
How bad were your original springs? Did you just replace with new factory springs?
Just trying to figure out what rubber to put on my new rims!!!!!!!
Where and how were the 33's rubbing?
Is it because of the width of the tire?
Posted: Sun Mar 14, 2010 12:34 am
I've got 295/75R16s (theoretically 11.6" wide, 33.4" dia.) on my 712W, and I get a slight rub at the front of the passenger tire since that axle is 30mm farther forward than the drivers side. I do have new, heavier springs on it as well. I can see that even this size is too wide for my taste especially if you do any hard core wheeling (I don't with this truck). IMHO, if you really want the diameter you ought to stay with narrower tires; or if you want the width for flotation (steering becomes a bugger with wide tires, too) then I wouldn't go above 33" diameter. Pick your poison.
Posted: Sun Mar 14, 2010 12:50 am
by ABSOLUTSECURITY
Thanks Jim! I think I will stick to 33's then and I am not going to beat this ride with heavy hard core wheeling so I wont mind a itty bitty rub ! If I want to beat something to death I will buy a beater! :D
So do you think 33x12.50R17LT will be OK?
Posted: Mon Mar 15, 2010 6:39 pm
I guess it depends on what your rims are like (for offset and width). I've got the "standard" 8" custom rims that were made with the stock center, but new rim portion. I don't know what the offset really is, but most of the rim width increase appears to be on the outside I don't get any rubbing at steering lock with these (with no hard articulation, anyway).
If you have similar rim ofsets I would expect you to be OK.
Jim
Posted: Mon Mar 15, 2010 7:05 pm
by ABSOLUTSECURITY
Jim
I got 7 of these:
http://www.hummerproducts.com/17%20Wheels.htm
Posted: Wed Mar 17, 2010 6:33 pm
by ABSOLUTSECURITY
HELLO!!!!!!!
Posted: Wed Mar 17, 2010 10:55 pm
by dokatd
This is the slowest forum I have ever been on. Amazing it even stays alive. Good luck.
Posted: Wed Mar 17, 2010 11:38 pm
by ABSOLUTSECURITY
dokatd wrote:This is the slowest forum I have ever been on. Amazing it even stays alive. Good luck.
They are slow but DIEHARDS! LOL!!!!!!!!!
Posted: Thu Mar 18, 2010 3:08 pm
by McCall Pinz
Kinda like our trucks
Posted: Thu Mar 18, 2010 4:29 pm
by ABSOLUTSECURITY
RIGHT!!!!!!!!!!!!!! :wink:
Posted: Fri Mar 19, 2010 4:52 pm
by Higher Ground
So it look's like a narow 34' tire will work . The Interco Super Swamper # sam 21 is 34" x 9" on a 16" rim .
Posted: Sat Mar 20, 2010 8:03 am
I installed radial TSL swampers this past winter. Just got 'em dirty 2 days ago, and even with the spring dampness, I'm climbing hills I couldn't do last summer. (Of course my old tires were a bit long-in-the-tooth) These tires rock.
Posted: Mon Apr 12, 2010 10:12 pm
by Pinz Enthusiast
Paul,
Great choice in tires, I am on my 3rd set and love them (265/80R16's), cost a lot less than wrangler mtr's or BFG's and so much more traction, 2 weeks ago I was sent out on a vehicle rescue by the forest service, it was a 09 GMC 3500 lifted with huge tires and weighing over 8,000lbs stuck in slushy/muddy snow about 2 feet deep, very high sentered, i pulled up behind him hooked up my strap and got him out in 3 shorts snaps, even in the sloppy conditions I had lots of traction, but deeper snow did eventually boog him down so even I couldnt get him out till early the next morning when the snow and mud were frozen, I love these tires though I might change to a LT size for my next set.
Posted: Tue Apr 13, 2010 12:54 pm
by roadrash
Ooooooooooo. Based on advice I received from a long time pinz person, I ordered interco trXus 33 x 12.5 x R17's today to go on the custom aluminum rims of my 710K. Hopefully there were be NO rubbing or issues.
