Re: Turn signal indicator keeps flashing.
Posted: Mon Oct 10, 2011 7:36 am
Hi Pete:
Thanks for posting to the Board and helping us out. I just wanted to post about my experience with the flasher gremlin. As Pete noted, I changed out the flasher relay and, while I was at it, improved the ground to it. While that helped, the phantom flasher kept flashing. It just wasn't as frequent; but still was an aggravation. I then took the turn signal itself a part and cleaned it and then reinstalled it onto the column and made sure the collar was tight to the steering column. Based upon Pete's suggestion, I then took the hazard flasher loose, found a somewhat loose connection to it and tightended it. THe bulb inside the hazard flasher was out and I replaced it. After putting the flasher switch back together and installing it my phantom flashes have all but gone away. Every step of the way the problem got better. But I think Pete is right in that the bulk of the cause for the phantom flashing is the hazard flasher switch.
If the problem returns, I'll change out the flasher switch.
Pete, thanks again for the input and hopefully this will assist someone else with the same problem.
John
John
