Bosch 0190215006 Voltage Regulator substitutions?
All things body or wiring related
Re: Bosch 0190215006 Voltage Regulator substitutions?
pinzinator wrote:I also bought one from the EBay listing, just in case I ever need one in the future. You never know when a 50 year-old regulator might fail. Probably the day the last one is sold, then the price really goes up!
Jim's post was for a NA Hafi that uses 0190215003
Other Hafi's used 0190215006 (as per OP) which does not cross reference to the one Jim posted
Just letting everyone know - it may still work
For Hafi owners that don't own a NA Pathfinder Hafi here is a voltage regulator
http://www.ebay.com/itm/Steyr-Puch-500- ... SS:CA:3160
Here are the two regulators side by side. The one on the yellow box from EBay on the left is made for the European Haflinger, the one on the right is the kind Jim and I bought. The major
difference I see is a resister running vertically on the right side of the unit on the right. Jim, I hope you can give an opinion.
Image Image
Yes - the way I see it...
The one you purchased is for a NA Pathfinder Haflinger which I would buy off of you and you should purchase the current eBay one for your Hafi
Sounds like a deal, send me a PM with your email address so I can get necessary info.
The mil spec units may not use the resistor due to other inline resistors not found on any other models.
I will try to post better info after I get another close look at a Swiss Mil spec unit 8)
