Re: Finished.....710K before and after
Posted: Wed Aug 20, 2014 12:39 pm
What he is referring to is that when you pull down from the front pintle, the front clip of the Pinz can bend forward and down, releasing the front doors.
The 710/12s do not have safety latches that will keep the doors closed in case of a collision.
When I sold my 712 (many,many moons ago
), the flat bed driver put tension on the front pintle to compress the suspension and both front door popped open like air brakes on a P47
. That is why I advocate using the outriggers, or through the steering cutout in the front extension.
Later 716/18s all have tiedown loops on the outriggers at the body mounts and on the front extension.
Ks are more difficult to have this happen because of the roof structure.
M&J, your tying the fronts at a angle rather than straight forward also reduces the amount of tension that can be exerted by hand.
AC, I had noticed it too, but let him slide because of the last 2 factors.
And for anyone that doesn't believe it, check all the gaps around the your doors, and read Miles' thread on his truck rebuild , and on how he re-straighten the front clip alignment.
