Page 4 of 4
Re: KLUGEWERKS Disc Brake Conversion Kit Updates
Posted: Mon Aug 20, 2018 3:52 pm
by VinceAtReal4x4s
I'm showing a last log-in date of July 5th for him.
Posted: Sat Nov 17, 2018 1:30 am
by Sam_Pinzgauer
Good day,
Tryed to get in touch with you, yet have not got an answer. Could you please send your contact details? I wanted to purchase the conversion kit for 712 Petrol Pinzgauer. Can you ship it to Kazakhstan?
Best regards,
Sanjar
Posted: Sun Nov 25, 2018 10:57 am
by Derrickbwg
Im installing the disc kit this weekend and Im running into some issues with the items he sent vs. what the instructions say I should have. 15" lines labeled "@ caliper" when diagram shows 12" lines. Some of the allen head bolts for adapter plates are longer than others, no fittings for mounting brake lines to the calipers (instructions showed them and I was able to source same locally) and the instructions I received do not have any info for installing the rear brakes and plumbing.
I can order the correct size lines and bolts if necessary but I would like to have some documentation on the rear brake install. Does anyone have the instructions for the rear? I ordered fairly early and did not get the revised instructions.....dont know if he even ever finished those or not. Any help would be appreciated.
Posted: Sun Nov 25, 2018 2:53 pm
by rmel
Contact Andre at Fatfab, he's done a number of these conversions
and also made some simplification mods. Good luck!
Posted: Sun Nov 25, 2018 5:18 pm
by Derrickbwg
Good to know. I'm heading to rockwall TX on the 29th and I'm going to run over to Andres to pick up some tank/battery box guards he made for me. I'll pick his brain on the conversion when I see him!
Sent from my SM-G935V using Tapatalk
Posted: Mon Nov 26, 2018 1:29 pm
Its such a shame that Chris just disappeared from this forum, his phone and email.
Such a great kit but lacking the last few details to make it seamless.
I have not stated to install my kit but get more and more nervous with each post as I was hoping it would be bolt-on and go vs trying to guess which bolt and hose to use. I don't want to start to then have my truck unusable for weeks while I try to guess parts on my braking system!
Disappointed to say the least but as I have said in the past (in this thread)... something is not right! Not sure if he's sick, moved or passed but something weird is up!
Posted: Wed Nov 28, 2018 2:48 am
by Hotzenplotz
apologies for my blunt approach
is there no member of this forum living in the vicinity of the address posted on klugewerks.com ?
"drive by, knock on the door and say hello" would be my solution to this open question.
I also considered this kit for my truck.
Current plans will get me to Seattle around Easter week, so unless this topic is solved by then I will head out into the wilderness, look and report back
Posted: Wed Nov 28, 2018 9:57 am
by GadgetPhreak
I live about an hour away and have been to his shop a number of times. I've also tried calling/texting him multiple times over the summer. I haven't had any luck finding him. At this point I think something has happened to him. Sadly I don't know his family so I'm not able to verify that with certainty. I don't expect that we will hear from him again
Posted: Tue Jan 22, 2019 4:15 pm
by Mryak
The install on my pins was easy Peary!
Posted: Tue Jan 22, 2019 10:33 pm
by Pols497
What kind of wheels did you go with. I like them.
Posted: Wed Jan 23, 2019 6:46 am
by Derrickbwg
Mryak wrote:The install on my pins was easy Peary!
Do you have the instructions for the rear brakes or did you do fronts only?
Posted: Tue Jan 14, 2025 11:33 am
by eric82000
Hello everyone
no news from Chris
anyone have the DXF of the brake plates?
thanks
Eric
