Page 1 of 3
Reduced Price - Aluminum 5 Bar Rear Top For Sale - $1000
Posted: Sun Apr 10, 2016 1:04 am
by Haf-e
I have decided to put up for sale the aluminum rear top I built for my Pinz 710M. It is made from a single sheet of 5 bar type aluminum plate - 3/16" thick by 5 foot wide by about 9 feet long. I curved the sheet and welded it to a curved internal aluminum frame - it then rests on the front a rear roll bars like the original tarp cover does so it doesn't add significantly to the overall height - the welded on frame work fits between the front and rear roll bars. The roof is super strong due to the welded curved frame under it - its all aluminum and I can move it myself - so perhaps 100 lbs total with the side curtains? There is a foam rubber type ceiling material I added that keeps the roof from dripping when I used to sleep in the back when camping.
Aluminum 5 Bar Pinz Rear Top.jpg (987.78 KiB) Viewed 10430 times
The aluminum has a dull / mat / flat type finish which looks good on a Pinzgauer - but it could be polished I suppose if you wanted too.
I did add two grab rails along each edge - they are also aluminum and are welded on - I used this to attach a roof tent and a solar array for a while. It is great for tying down items on the roof also or just to grab when climbing up the sides. These rails didn't add to the overall height actually since the roof is curved - this was important for avoiding higher costs on the local ferries her in the PNW and Canada. I also have put two lengths of 1 inch steel EMT conduit into the grab rails from the back to make a nice awning / shade cover support.
Aluminum 5 Bar Pinz Rear Top - Front Edge .jpg (824.77 KiB) Viewed 10430 times
I am including the two original pinzgauer side curtains which roll up. They were painted black using Krylon vinyl paint which works really well. I will also include the matching black front edge flaps with it. There is also a very nice glass marine hatch that measures 14 x 14 inches installed which does not leak - it could easily be replaced with a RV type hatch with a fan - they use the same size opening but would add to the height and be more vulnerable to branches, etc.
Aluminum 5 Bar Pinz Rear Top - Hatch.jpg (885.22 KiB) Viewed 10430 times
Aluminum 5 Bar Pinz Rear Top - Hatch Open .jpg (553.06 KiB) Viewed 10430 times
The rear was set up with two side plates that held water cans and a center glass hinged "hatch" that lifted up - it could also be easily done with a side opening upper door section with Andre can supply from what I understand. I actually want to keep the rear hatch for my new top I am making - but, if desired, I would sell it too. I'll include the two rear side plates of 5 bar aluminum with the top if desired.
Aluminum 5 Bar Pinz Rear Top - Back Open.jpg (768.86 KiB) Viewed 10430 times
I do have one more 5 foot x 5 foot piece of the 5 bar aluminum left and some additional pieces that I would consider selling as well - It is enough to make a front roof section with it that would be separately removable. The rear aluminum top works very well with the original front top BTW - although the antenna mounting plate on the front roll bar might require some trimming of the aluminum rear top - on my Pinz I had removed that part to reduce the overall height.
So - I am asking $1000 (reduced price) for the rear top with the side curtains included and the two 5 bar aluminum plates for the back. The rear glass hatch would be extra / negotiable - along with the additional 5'x5' sheet of 5 bar aluminum.
The roof is located north of Seattle but I could also bring it to the NW Sprinterfest just south of Portland in May, Sheridan in June or to the NW MogFest in August as I should be at all of those events. Shipping is possible but probably would be too expensive. I might also be driving my sprinter down to CA in late Summer so that is another possibility.
Re: Aluminum 5 Bar Rear Top For Sale
Posted: Sun Apr 10, 2016 10:31 am
by Justin Case
Will you post some pictures of it installed on your Pinz. I am in the Boise area and am interested in it
Posted: Sun Apr 10, 2016 12:20 pm
by Haf-e
I have few photos of it on the Pinz and my truck is currently apart for repairs in the garage. Hopefully it will be out in a month or so.
Here are a couple of shots - one with solar panels mounted on the side which were covered up if I rolled down the fabric - it also shows the roof tent on top. The second is with a aload of firewood in the back and the sides were loaded up also.
I'll check for more photos on my back-up drive later today.
Posted: Sun Apr 10, 2016 10:50 pm
by NEWFISHER
So cool! If I wanted a hard top I would be owning this one. Nice work.
Ps....the playa?
Posted: Mon Apr 11, 2016 12:22 am
by Haf-e
Thanks for the generous comment.
Yes - took the Pinz there in 2002 and 2004.
Posted: Mon Apr 11, 2016 2:11 pm
Would be pretty tough to find a sheet of 5 bar aluminum to recreate this one piece roof!
Good luck with the sale.
Posted: Mon Jul 25, 2016 12:09 am
by GadgetPhreak
Chris, is the roof still available for sale? Id like to come look at it.
Posted: Mon Jul 25, 2016 12:02 pm
by Haf-e
Yep... still available. Was going to repost in case someone wanted it delivered to NW Mogfest.
I'll be around all this week.
Posted: Wed Aug 17, 2016 12:53 pm
by Haf-e
This custom aluminum rear top is still available and delivery to the NW MogFest is possible.
Let me know if you are interested.
Posted: Mon Dec 19, 2016 4:42 pm
by Haf-e
Bump - still available... deliver to as far as San Diego possible in March 2017.
Posted: Tue Dec 20, 2016 12:13 pm
by whitesik
Do you till have the 5 foot x 5 foot piece of the 5 bar aluminum or the extra pieces that you mentioned? Might be interested if it can come to Indiana.
Posted: Tue Dec 20, 2016 12:52 pm
by Haf-e
I do have the 5' by 5' piece of 5 bar aluminum and a few other pieces - but I am reluctant to sell it without selling the rear top first as it is ideal for making a front top to match.
If I sell the rear top and still have the 5' by 5' piece I will let you know. I think Fedex will actually ship something that large actually. Would need to check on that though.
Posted: Tue Dec 20, 2016 1:11 pm
by whitesik
Thank you sir! Keep me in mind.
Re: Reduced Price - Aluminum 5 Bar Rear Top For Sale - $1000
Posted: Mon Apr 03, 2017 3:11 am
by Haf-e
Still available. Reduced price to $1000.
Posted: Wed May 10, 2017 10:57 am
by Haf-e
Still available
